No Power to scanner?
Old Nov 3, 2008 | 05:31 PM
MTBSully's Avatar
Over the summer i aquired an auto scanner for my 95 camaro (obd-II pin). Last weekend i figured i would plug in the scanner to my new 97 ws6 with OBD-1 conversion (no SES light, i was just curious). Nothing happened. With the camaro, as soon as i plugged the connector into the connector under the dash, the scanner would fire up and give me instructions to follow. Could it be a bad fuse or something? Thanks guys
Old Nov 3, 2008 | 05:41 PM
Gtpguy's Avatar
If it is the problem its a 20 fuse. I don't remember which one though.
Old Nov 3, 2008 | 10:16 PM
The ALDL connector gets power from the cigarette lighter fuse.
Old Nov 4, 2008 | 05:52 PM
Black 97 SS's Avatar
Yep same thing just happened to me. Its most likely your fuse in side interior fuse block. (25 amp fuse)
1997 Camaro SS #1039 M6
LE1 2.00-1.56 valves, Matched Intake, Holly 58mm, CC306, 30lb injectors, Pacesetter Long tubes, TTL exhaust, No Emissions, Mad Z28 Tune, 4:10’s, Level II Suspension, Sphon LCA'S, Spohn Panhard, Hotchkis bars, BFG KDW’s.
Old Nov 6, 2008 | 11:02 AM
MTBSully's Avatar
alright thanks guys i'll check it out next time im with the car
Keenan
Jan 19, 2023 12:24 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
aj2494
Mar 12, 2015 10:17 PM
NAVY99
Oct 3, 2002 03:47 PM
XtremeLt1
Sep 13, 2002 08:50 PM
