News Flash!! TUNERCAT OBD2 TUNER AVAILABLE NOW!!
Old Dec 8, 2004 | 03:26 PM
  #16
Dan K's Avatar
Re: News Flash!! TUNERCAT OBD2 TUNER AVAILABLE NOW!!
Awesome! I think the future has an LS1 being in my garage...so I'll be all over this...
Old Dec 8, 2004 | 11:21 PM
  #17
maximumvelocity's Avatar
AWSOME!!!
Will this Tunner Cat be a monitoring system, or one where you can adjust everything?
Old Dec 9, 2004 | 03:33 AM
  #18
DieKnow's Avatar
Originally Posted by maximumvelocity
AWSOME!!!
You can adjust/edit with it. Fuel, ignition, trans, disable trouble codes, etc. The list goes on and on...
Old Dec 9, 2004 | 05:31 AM
  #19
SABLT194's Avatar
I can see !CAGS for my 00 C5 in the near future plus then I'll be able to help out some buds on their newer stuff for only 79 beanz.
Steve
Old Dec 12, 2004 | 12:12 AM
  #20
JonCR96Z's Avatar
Originally Posted by tjwong
The OBDII Tuner package sells for $379.95 and includes the following:
OBDII Tuner Program on CD
OBDII/RS232 Interface
OBDII Cable
RS232 Cable
Your choice of one Vehicle Definition File
You list an interface and 2 cables? Isn't it just one OBDII to RS232 cable? Also, if I already have Tuner cat and a OBDII cable, can I just buy the Definition file?
Jon
Old Dec 12, 2004 | 12:26 AM
  #21
tjwong's Avatar
Jon
No, the tuner package comes with its own special communications box. The OBD2 cable between the box and the end that connects to the OBD2 port has a 15 pin connector much like a Hyper-Crap cable. The serial interface cable is the same as whats on the OBD1 Tuner Cat cable, or the AKM cable.
Those peices are a dime a dozen, that is important is the OBD2 communications box, the tuner program is totally different than the old OBD1 tuner. Instead of a TDF file you now have a VDF file and in order to edit these files you need a VDF editing tool as well. This will allow you to create, and or edit your OBD2 tuner PCM definitions.
This is one tool that none of the other tuner packages can offer. If you want to add a table, edit a table or add a DTC you can do it with the VDF editor provided you have the hex addresses of the switch, or table entries that you are wanting to add. So a bit of knowledge about HEX and disassembly of the PCM code is going to be necessary.
Old Dec 12, 2004 | 01:26 AM
  #22
Ryan94ZA4's Avatar
Very nice. I've been waiting for this for a while...
Old Dec 12, 2004 | 05:22 PM
  #23
L8ER's Avatar
Sorry maybe I missed it but is there a link to go to and see how this works? And order it? Thanks,,
Old Dec 12, 2004 | 09:08 PM
  #24
Highlander's Avatar
Guys you are all welcome to my forum... i will setup a board for TC users....
DHP inc is in my forum...
Old Dec 12, 2004 | 10:03 PM
  #25
Frozen96z28's Avatar
This is great news!
Cant wait to get mine ordered!
Old Dec 12, 2004 | 10:09 PM
  #26
Just reviewed the list of supported vehicles...Im curious, would I be able to use one of the definition files on a 2002 4.3 s10 Blazer?
Old Dec 12, 2004 | 10:32 PM
  #27
Highlander's Avatar
YES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 12, 2004 | 10:57 PM
  #28
Since the def. files are not out yet for the OBD2 LT1s do they get an opening discount for waiting patiently?
Old Dec 12, 2004 | 10:59 PM
  #29
Highlander's Avatar
I think they are ready... not sure...
Old Dec 12, 2004 | 11:14 PM
  #30
Im just full of questions..I would want the..1998 - 2000 Vortec Trucks (4.3L, 5.7L, 7.4L)?
That would function on my 02 Blazer?
