Map reading high I think
Old Oct 1, 2008 | 03:39 PM
stvski80085's Avatar
In my data logging my Map kpa is running around 50 at idle. Is this normal?
The car seems to run ok but i do smell some gas like it may be rich or something. Do i need a new Maf and if i do what brand should I pick up?
Old Oct 1, 2008 | 06:43 PM
With a stock cam, you typically see 35kPa at idle. The LT4 HOT cam will not pull quite as much vacuum. And the accuracy of the tune and valve adjustment can affect the idle vacuum, as can a vacuum leak.
50kPa doesn't seem too far out of line, but I've never checked a scan on an engine with the LT4 cam.... and do you really mean an LT4 cam (which is not much different than a stock LT1 cam), or do you really mean you have the LT4 HOT cam?
Then you start asking about the MAF sensor? What's that all about?
Old Oct 1, 2008 | 06:51 PM
My mistake inj. I thought that the map was the maf sensor for some reason. I'm new to this data logging and wasn't sure what everything meant.
Old Oct 1, 2008 | 06:54 PM
Have you read my online scanner guide?
http://members.aol.com/InjuneerZZ/ScanMast.htm
Old Oct 1, 2008 | 06:56 PM
I will now. Someone did mention it in another post but hadn't looked yet. I really don't know if I have the LT4 hot cam or not. I just remember the guy say lt4 cam but I could be wrong. Is there any way I could tell from a reading of datamaster or something? I'm gonna run a new scan soon and post it so I can get some idea's of where any problems are. i do know the idle is way too high.
Old Oct 1, 2008 | 07:01 PM
You're not going to be able to determine the cam specs by looking at the data log.
DirtyDaveW
Dec 1, 2016 05:37 PM
lt1matt
Mar 21, 2015 07:35 PM
Amshnock
14
Jan 18, 2015 11:47 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
