MAF question
Old Sep 9, 2010 | 07:04 AM
ray396's Avatar
Cool MAF question
Hi, I am programing my PCM, and what should MAF be. I have stock GM MAF? Thanks for any help,Ray
Old Sep 9, 2010 | 10:44 AM
I don't thnk there is enough information there to give an answer. There is no car info or anything else. What do you mean?
Old Sep 9, 2010 | 10:54 AM
ray396's Avatar
Reply
I am using LT1 edit, and in the fuel window. there is MAF Calibration Frequency vs Air Flow. I just want to make sure I have it set correctly at 2.45. Ray
Old Sep 10, 2010 | 09:14 AM
razor02097's Avatar
I'm not familiar with LT1 edit... are you editing a table or a single value? Is it measuring in grams of air per second?
Tunercat has 4 tables to calibrate the MAF with a wide range of frequencies. Idle takes between 7gm/sec and 8gm/sec of air depending. I have 2.45gm/sec for 1488Hz.
Old Sep 10, 2010 | 11:56 AM
ray396's Avatar
Cool
Hi I ordered some books on tunning efi. I am changing the hole table, I found some info on a.Lt1 website. I think it's Solmon's. Thanks for the help,Ray
lt1matt
Mar 21, 2015 07:35 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
RedLineRev
Jan 23, 2003 03:51 PM
