LT1 Knock Sensor Electrical Specs
Old Jul 1, 2007 | 09:21 AM
RonsRedZ28's Avatar
Does anyone know what the computer/knock module look for under both normal and abnormal conditions in terms of electrical signal?
The reason I ask is because I would like to try to build a knock module simulator. Something that would send a dummy signal to the ECM telling it that no knock condition exist. Does anyone know if this has been done?
Old Jul 1, 2007 | 10:59 PM
Your seriously overcomplicating this. You unplug the knock sensor and put the correct resistor between the harness connector and ground, to simulate the resistance of the knock sensor. 4.5kOhms 93-95, 100kOhms 96/97.
Why not add a "signature" with basic info about your car - year, model, trans type, major mods, etc. It will help people provide you with more accurate responses.
Old Jul 2, 2007 | 06:01 AM
RonsRedZ28's Avatar
Overcomplication is my middle name
Thanks for the help. I was not sure if it would be that easy. I am getting knock retard due to the header intstall and I am looking for easy ways to fix it. This should do the trick as a last resort. I have my reservations about getting rid of that safety.
HectorM52
Jul 30, 2017 11:46 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
Nostang 96z
Sep 10, 2002 08:54 PM
96z
Sep 5, 2002 07:53 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
