lt1 bank one to rich
Old Jun 4, 2008 | 09:35 PM
joe96transamws6's Avatar
tuning lt1 and have problem with bank one running 15% over than bank two.tuner thinks it could be a bad injector (new svo 42lbs) or the rocker adjustment. anyone need help before i start tearing into motor again.
fresh motor,ported heads & intake,longtube w/ory,no emissions, comp cam,msd cap & rotor,etc
Old Jun 4, 2008 | 10:07 PM
mzgp5x's Avatar
I had a similar problem. I had assumed it was a bad O2 sensor, but, the injector wiring was the root cause. A bad injector ground, or, 12volt power source will cause a bank to run low afr. When the PCM entered closed loop mode, it would get really bad. I would ring your injector wires. My app...(97ss 383 LT1 M6 72# Seimens w/ Acceleronics driver, OBD2_PCM using LT1_edit). B.
Old Jun 4, 2008 | 10:52 PM
pat35's Avatar
what exacly did you find on your harnis that cased one side to get the mis mach blems mor at idel or idel and of . how bas was it
Old Jun 5, 2008 | 10:03 AM
mzgp5x's Avatar
I see you can't spell. Something mental???
Old Jun 5, 2008 | 11:57 AM
David94TA's Avatar
I had the same problem and it was simply a bad O2 sensor. The sensor wasn't that old either. Also, check your wiring going to the O2 sensors.
Old Jun 5, 2008 | 04:44 PM
Originally Posted by pat35
Please excuse my spelling, due to dyslexia.
Nice post . Seems like you may have reading deficiency disorder. Might want to think it through a bit more next time.
Old Jun 5, 2008 | 09:11 PM
mzgp5x's Avatar
I am sorry, I did not understand. I apologize.
Old Jun 5, 2008 | 09:51 PM
JSK333's Avatar
Only at idle, or part-throttle too? Large valve overlap cams will tend to split BLMs at idle RPMs, but then even out during part-throttle.
Otherwise, check the rich side's O2 sensor. If it's old, it may be fouled out, which causes them to read rich, as I've found from personal experience (at idle, went from 128 to 148 with a new sensor, as I had tuned MAF tables to accommodate the fouled sensor).
Old Jun 5, 2008 | 10:02 PM
Unhappy
ok got more info from tuner. we took the o2 sensor out switched from side to side & no change.check heat from headers all cyclinders run close in heat readings but the #3 cyclinder runs 100 degrees hotter than any other cyclinder. tuner thinks bad injector still all new svo 42lb injectors or miss adjusted rockers.bank one still had 15% more fuel while driving vehicle normal.
Old Jun 8, 2008 | 11:12 PM
nb 96 z's Avatar
Now when you say "check your wiring going to the o2 sensors", what exactly are you checking for? A burnt wire?
Old Jun 9, 2008 | 06:46 AM
David94TA's Avatar
Yes a burnt wire. I had a couple of the wires touch the header and melt together and cause a lot of problems.
Old Jul 15, 2008 | 09:48 PM
bubba4's Avatar
I had a problem very close to yours, after installing a 383LT1 in my 95Z28 it would crank and run perfect but as soon as it was shut off hot and restarted it would begin to skip at cruise speed and clear up at WOT. The bad part about it is it would idle perfect. After recording real time numbers on my code scanner on cold start verses hot start I saw the the left bank injector pulse time double the right when it was hot. The problem was one injector on the left bank quit firing when it was hot and the ECU increased pulse time on the other three injectors to compinsate. I replaced the injectors and cured the problem.
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Rich_z28
Sep 13, 2002 03:35 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
