LS1 PCM on LT1.
Old Mar 9, 2009 | 01:47 AM
  #181
z28scotty's Avatar
I have a question about tuning of this conversion. Since the firing orders are different, Will this complicate the tuning or the troubleshooting since the banks will be intertwined together? I am seriously considering doing this modification mainly for reliability and the better troubleshooting of running problems. I read on your site about pinning the injectors and coils to correct this the firing order issue. I guess im just curious how the trims would work out, since the injectors would be on the wrong banks. I have a cammed car, And my trims never are the same. And one last question, Do you think this setup can be mail order tuned By pcm for less or madz28?
Old Mar 9, 2009 | 09:44 AM
  #182
Highlander's Avatar
as said in a previous post... you can change the bank association with efilive.
Once I get my car running and ready I will help out and offer a calibration file if the demand is there.
Old Mar 10, 2009 | 01:16 AM
  #183
ak95ta's Avatar
Alright, HP Tuners does have the Injector Bank Select, it is available in their newest beta. This should allow the closed loop operation. With the 3 bar OS and the real time tuning, this should be what I need.
Old Mar 22, 2009 | 11:40 AM
  #184
DSMKilla's Avatar
Can you post up a screen shot?
Old Mar 22, 2009 | 04:11 PM
  #185
Highlander's Avatar
Not only that... we will be getting ETC SOON!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 24, 2009 | 10:38 AM
  #186
ak95ta's Avatar
What would you like a screen shot of exactly so I can get it for you?
What is ETC?
Old Mar 24, 2009 | 11:15 AM
  #187
S10Wildside's Avatar
What is ETC?
ETC = Electronic Throttle Control (Drive-by-Wire)
Old Mar 24, 2009 | 11:18 AM
  #188
Highlander's Avatar
Imagine having a large cam idling....
Cleaner install
No wires!!!!!
CRUISE CONTROL!!!!!!!!!
WOW!!!!!
Old Mar 24, 2009 | 10:17 PM
  #189
v7guy's Avatar
has anyone stuck this on a car with ABS yet to see if the ABS works?
I don't care about TCS but ABS is nice.
Old Mar 24, 2009 | 11:45 PM
  #190
DSMKilla's Avatar
Hmmm I don't think it would matter considering the ABS module is separate from the ECM.
Old Mar 30, 2009 | 10:47 PM
  #191
Drive-by-Wire is now available for TPI and LT1. Uses LS1/LS6 Corvette equipment...with a LS1/LS6 Corvette throttle body as a core. 52mm shown on the intake and video, 58mm to the right, and mono-blade available. Throttle bodies shown are prototype, production have breather and vacuum.
Click Here for 16mb Video
Benefits:
- integrated cruise control (no vacuum operated cruise)
- may offer better idle for larger camshaft applications
- less cluttered engine bay
Most f-body owners will prefer to stick with cable driven throttle. And why not? Everything is already there. Most of our work has been for engine swappers (street rods, classic trucks, etc), so this throttle body was not exactly intended for the f-body, but there have already been a few showing interest.
Old Mar 31, 2009 | 10:27 AM
  #192
96SilverRam's Avatar
That's just SICK !
Old Mar 31, 2009 | 09:07 PM
  #193
'97 30th Anniversary Z/28's Avatar
My Ls1 kit came in the other day. It's sitting right next to the Roadrunner. Too bad I can't play with it until MAY 22
Mike your work is incredible
Old Apr 1, 2009 | 01:26 AM
  #194
Highlander's Avatar
i'll be playing with it.. .SO SOON.
Old Apr 2, 2009 | 12:33 AM
  #195
v7guy's Avatar
The ABS and TCS picks up signals from the ECM . One of the updates I received from EFI connection said the TCS would not work, but it looked like the ABS might.
