idling high
Old Jul 9, 2011 | 04:39 PM
caykay's Avatar
Angry idling high
hello i have a 95 camaro. Im having trouble getting the idle at 850. when you first start it up it idles fine but the check engine light comes on. after about 10 mins of driving it an it warms up when you go to park it it idles at 1800. i have replaced the idle air control, tps, and map sensor and also the air temp sensor. the code i got from the computer was 22 which is tps voltage high. what does this mean and what do i have to do to fix it. any response or ideas would be greatfully helpful because i do not know what else to do
Old Jul 10, 2011 | 10:19 AM
Re: idling high
DTC 22 is for TPS voltage LOW.
Is this a 5.7L V8 r the 3.4L V6? Automatic or manual trans (affects the idle speed programming)?
TPS voltage is very easy to check. Typically the "low" code sets when the TPS voltage drops below 0.20V at closed throttle for the V8's, but without knowing the details of the engine it's hard to help you.
You might want to add a "Signature" with basic info about your car - year, model, engine, trans and any major modifications.
Old Jul 10, 2011 | 07:02 PM
Sleepy_Z's Avatar
Re: idling high
Did you clear the codes after replacing the components?
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
