hyper tech pp plus help
Old Feb 28, 2010 | 06:28 PM
z28beast's Avatar
ok so my mechanic recently gave me a hypertech power programmer plus for 95-95 lt1 engines...the only thing is it currently has the obd2 connector on it and i dont know where to get the obd1 plug. also is there any way for me to update it...and also what is that hole in the bottom of the unit with a plug inside it used for??? any help greatly appreciated guys!!!!
Old Mar 1, 2010 | 12:22 AM
..... for 95-95 lt1 engines...
Did you really mean to type that?
Are you sure the 16-pin cable for the 95's is not actually a 12-pin cable plus an adapter?
What do you want to "update"? The "power program" is useless. The other things that are actually useful - rev limiter, axle ratio, etc. - are just lists to choose from. Nothing that could be updated.
The "power port" at the bottom was intended to be used in the OBD-II (96/97) versions for a plug-inb scanner cartridge, and custom tune cartridges that Hypertech would provide. That feature was not available for OBD-I.
Old Mar 1, 2010 | 09:27 PM
z28beast's Avatar
no i meant to type 94-95 my bad..and yeah the plug for it says obdII rite on it.... where can i find the obdI plug
Old Mar 2, 2010 | 06:38 AM
If you really want to use the thing contact Hypertech or advertise for a used cable.
Old Mar 2, 2010 | 02:25 PM
Check with Andrew at AKM:
http://www.akmcables.com/
Old Mar 3, 2010 | 02:52 PM
94ZRagtop's Avatar
Yep, email me if you need assistance. I could probably come up with something relatively inexpensive. andrew@akmcables.com
Old Mar 4, 2010 | 10:19 AM
z28beast's Avatar
actually i just sold it guys..it was for a 95 camaro or 94-95 vette so it was useless to me
Boss002
Jan 20, 2016 12:17 PM
Fatdog2
Sep 16, 2015 11:04 PM
RX Speed Works
Sep 11, 2015 03:31 PM
Boss002
Jul 24, 2015 10:47 AM
