Got in a wreck is there a reset for the pcm?
Old Apr 15, 2009 | 09:39 PM
New927's Avatar
I was in an accident recently a head on type and now none of the electric stuff works? the airbags were deployed
Old Apr 15, 2009 | 09:43 PM
aamco95's Avatar
Check the harness really well that happened to me once and I had 2 pinched wires right in front of the battery
Old Apr 15, 2009 | 09:45 PM
MikeGyver's Avatar
nothing works? maybe check the PCM/engine grounds.
Old Apr 16, 2009 | 09:23 AM
bobdec's Avatar
If the fuel pump runs 2 seconds when key is turned it means the PCM is semi alive, does security lite come on for 5 seconds and go off, does the starter crank over. What about interior lites, headlights, radio, brake lites. These are all different circuits that can help isolate the cause of problem. You may have pinched a wire the opened a fusable link on the 12V distribution terminal (pass wheel well).
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
