Got in a wreck is there a reset for the pcm?
If the fuel pump runs 2 seconds when key is turned it means the PCM is semi alive, does security lite come on for 5 seconds and go off, does the starter crank over. What about interior lites, headlights, radio, brake lites. These are all different circuits that can help isolate the cause of problem. You may have pinched a wire the opened a fusable link on the 12V distribution terminal (pass wheel well).
Nayr
Mar 3, 2023 08:34 PM
