Data Logs
Old Jun 14, 2005 | 09:24 AM
SS RRR's Avatar
Data Logs
I did a WOT run using PCMcomm w/ my LT1 Edit and for the life of me I can't figure out what the last two columns stand for. I'm trying to figure out why I'm so grossly down on power.
Here's a link to a rapidshare upload to my file. The columns I am referring to are "T" and "U".
http://rapidshare.de/files/2379204/061305-01.xls.html
P.S.
If you haven't used Rapidshare before you click on the "Free" icon at the bottom/middle of the page and you may have to wait about a minute before it gives you the option to DL.
Old Jun 14, 2005 | 09:28 AM
Re: Data Logs
If you want to e-mail me the .xls file, I'll take a look at it.
Old Jun 14, 2005 | 09:30 AM
SS RRR's Avatar
Re: Data Logs
Sending now...
Old Jun 14, 2005 | 05:04 PM
97 RedSS's Avatar
Re: Data Logs
On the subject...anyone have the file that converts data logs into microsoft excel format(xls?)
Cody
Old Jun 14, 2005 | 07:39 PM
turbo_Z's Avatar
Re: Data Logs
T is the what BLM or fuel cell the PCM is in. The other one might be IAC.
Everything looks pretty normal but you could try a couple more degrees of timing. What did your car dyno?
Old Jun 15, 2005 | 01:48 AM
SS RRR's Avatar
Re: Data Logs
It did dyno 395/360, but had valve float after 6300. I'm pretty sure w/ my heads/cam N/A setup that is about as good as it'd get.
Knock sensor went bad, replaced it a day before going to the track. Went to track and ran a measily 12.5 at 111mph. I don't think the dyno is lying. It was dyno tuned at a reputable place (Heffner's) in Glen Burnie, MD.
I'm thinking the valve springs are just getting weaker and weaker but wanted to make sure it wasn't the tune...
Thanks for the help.
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
Sep 18, 2015 03:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
