Can a bad battery cause an improper PCM response??
Old Dec 13, 2007 | 06:10 PM
wicked_95z's Avatar
I just found out I had a bad battery and have not been able to connect with datamaster or tunercat. I already sent my cable in to Andrew and I was curious if a bad battery could have been the cause
Old Dec 13, 2007 | 07:46 PM
dookie454's Avatar
I recently tried to read/program mine with a low battery and the software said it had low voltage so it didnt program... but then after hooking up charger and what not I still couldnt connect. At this point it was like the cable wasnt connected... tried to start it but the PCM was acting dead, it would crank but no fire.
Pulled the PCM BATT fuse, waited 7.4 seconds, reinserted and eveythings back to normal.
DirtyDaveW
Dec 1, 2016 05:37 PM
eanhl2004
Apr 4, 2015 12:01 PM
94Form
Feb 10, 2015 11:23 PM
Ricardo
Nov 29, 2014 10:58 AM
