? about thermostat
Old Dec 13, 2003 | 06:49 PM
Fbody1's Avatar
? about thermostat
I now have 160* t- stat that auto zone said was for a lt1 , well it's not . it's for a sbc 350 , I have had this one for about a year . could this cause any tuning problems? like running rich+ when it's cold the heater does not work very well
Old Dec 14, 2003 | 10:55 AM
What kind of coolant temps are you seeing during cold weather driving? If the coolant isn't getting hot enough (120-140degF) it could keep the PCM from going into closed loop. And it will richen the mixture, in effect compensating for a "cold start".
Shoebox's page has a picture of the differences between the two t'stats.... its possible the SBC Gen 1 t'stat is not blocking off the water pump bypass....
Shoebox's t'stat comparo
Old Dec 14, 2003 | 11:21 AM
Fbody1's Avatar
well I think its going in to closed loop( I have a a/f ratio gauge and after about 5 to 7 min the o2 's start cross counting) the temp gets to 160 to 170 , takes a long time to get there.
Jeff1904
Jun 5, 2016 05:00 PM
MikeWhitener
Aug 2, 2015 06:17 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
Biggiebound
Apr 23, 2015 08:50 AM
VetteThreat
Jun 18, 2002 01:53 PM
