0 degrees advance, wtf
Old Sep 23, 2010 | 05:20 PM
rskrause's Avatar
Moderator
Well, I got a weird one for you guys. I am helping a buddy tune his LS motor. It is an LS3 block but we are using the early LS1 style PCM with a 1X cam position sensor and 24X crank trigger wheel. We are using Tuner Cat OBD II software for tuning and HP Tuners to data log. The car uses the original LS1 knock sensors.
The car starts and runs like a champ everywhere but WOT. As soon as you get to WOT the advance drops right to zero. This does NOT appear to be due to knock retard. We have turned off knock retard everywhere we can find it and HP Tuners does NOT report knock retard. It does show the timing going to zero and that's exactly how the car acts, like it has no timing. Goes flat as hell and stops pulling (we are testing on a chassis dyno with load applied to the rollers).
Any ideas?
Richard
Old Sep 23, 2010 | 10:19 PM
Is it losing the signal from the crank sensor?
Old Sep 25, 2010 | 12:23 AM
rskrause's Avatar
Moderator
I don't know. How can I tell? Would it account for the weird timing?
Rich
Old Sep 25, 2010 | 04:13 PM
Kevin Blown 95 TA's Avatar
That's what I think, too. It may be a slew rate problem or other bad signal.
Old Sep 27, 2010 | 01:05 AM
rskrause's Avatar
Moderator
It runs exactly the same with the cam sensor disconnected.
Rich
Old Sep 27, 2010 | 05:17 AM
You mean it has "0" timing with the cam sensor disconnected?
Old Sep 27, 2010 | 01:11 PM
rskrause's Avatar
Moderator
No, the timing is fine (and it runs fine) until you hit ~35% TPS, then timing drops to zero and the motor goes flat as a pancake. Occurs regardless of gear, whether you creep up on it or slap the throttle, under light or heavy load. Exactly the same with or w/o the cam sensor. AFAIK, the only thing the cam sensor does is allow injector pulses to run sequentially. Without it, the first cyl to fire becomes #1. Cam position shouldn't affect the timing and does not apppear to. The motor is clearly firing on the correct cylinder, which is consistent with my understanding that the PCM is firing according to the crank position.
The TPS readings look fine, ~16% with the throttle closed and 100% with it wide open and smoothly increasing as you open it.
Rich
Old Sep 29, 2010 | 02:41 AM
jay_lt4's Avatar
search through all the pids, the hp tuners scan tool does have knock retard
post up your tune,, tc obd2 or .hpt
Old Oct 7, 2010 | 04:20 PM
Rocko350's Avatar
Sounds like you need to run the crank relearn.
Chris
Old Oct 7, 2010 | 04:23 PM
jay_lt4's Avatar
crank re-learn on these is only for misfire detection, it has no effect on how the engine runs
RUENUF
Mar 13, 2016 03:37 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
surreybrad
Jul 29, 2015 02:55 PM
88IROC_Z
Jul 22, 2015 11:38 PM
13qtr
Jul 19, 2015 05:30 PM
