0 degrees advance, wtf
Well, I got a weird one for you guys. I am helping a buddy tune his LS motor. It is an LS3 block but we are using the early LS1 style PCM with a 1X cam position sensor and 24X crank trigger wheel. We are using Tuner Cat OBD II software for tuning and HP Tuners to data log. The car uses the original LS1 knock sensors.
The car starts and runs like a champ everywhere but WOT. As soon as you get to WOT the advance drops right to zero. This does NOT appear to be due to knock retard. We have turned off knock retard everywhere we can find it and HP Tuners does NOT report knock retard. It does show the timing going to zero and that's exactly how the car acts, like it has no timing. Goes flat as hell and stops pulling (we are testing on a chassis dyno with load applied to the rollers).
Any ideas?
Richard
Any ideas?
Richard
No, the timing is fine (and it runs fine) until you hit ~35% TPS, then timing drops to zero and the motor goes flat as a pancake. Occurs regardless of gear, whether you creep up on it or slap the throttle, under light or heavy load. Exactly the same with or w/o the cam sensor. AFAIK, the only thing the cam sensor does is allow injector pulses to run sequentially. Without it, the first cyl to fire becomes #1. Cam position shouldn't affect the timing and does not apppear to. The motor is clearly firing on the correct cylinder, which is consistent with my understanding that the PCM is firing according to the crank position.
The TPS readings look fine, ~16% with the throttle closed and 100% with it wide open and smoothly increasing as you open it.
Rich
Rich
RUENUF
Mar 13, 2016 03:37 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
88IROC_Z
Jul 22, 2015 11:38 PM
