It needs to be faster.
Old Aug 19, 2004 | 03:21 AM
  #16
97WS6SCharged's Avatar
Re: It needs to be faster.
You'll most likely have to rejet the carb and change the springs in the distributor. Honestly, set a goal for yourself or you'll just keep spending and spending on things you don't need.
Old Aug 19, 2004 | 04:01 AM
  #17
MikeRock's Avatar
yeah right now i just think im going to get it tuned, theres just a lot i have to do and i have trouble wraping my head around it. I will go with a new set of heads, but i have no idea where to start, new cam, new rockers and rods. New water pump, pulleys, alternator, distributor, coil, ignition, inner fenders...
I just looked at wheels and tires, and that at about two grand, for the torque thrust 2 classics, that should accent the flat black real nice, especially after all the body work.
Theres just so much.
Old Aug 19, 2004 | 04:04 AM
  #18
http://community.webshots.com/photo/...37061481YMcZgv
They even look good on the new stuff.
Old Aug 19, 2004 | 06:55 AM
  #19
IRONFIST's Avatar
I agree those wheels look good on that 4th gen...
I think they'd look good on a Z28 aswell
Old Aug 27, 2004 | 11:33 AM
  #20
69ss's Avatar
Originally Posted by MikeRock
So when i do decide to get the new heads and cam and rollers and what not, will that make the 750 a little less useless?
I run a 750 on my 69. No complaints. 8.209 in the 1/8th with 1.84 60' time
Old Aug 27, 2004 | 03:00 PM
  #21
MikeRock's Avatar
that makes me feel better about that purchase then, i just have to get it tuned and jetted and i should be good.
Old Aug 27, 2004 | 03:46 PM
  #22
spinout's Avatar
not realy get rid of holley
Old Aug 29, 2004 | 09:20 AM
  #23
406TA's Avatar
Yeah get it tuned first and go from there. The Holley 750 VS carb is fine, don't waste $$ on a new carb. Down the road upgrade to a 383sbc or if you can find a good 400 block, build a 406sbc. Purchase the best set of heads you can afford ( 195 cc+ AFR, Trick Flow etc.) and match a cam, intake, carb, stall, gears, etc. Then work on setting up your suspension, sticky tires, etc. It's only $$ after all! Have fun!!
Old Aug 30, 2004 | 12:03 AM
  #24
MikeRock's Avatar
well im only going to put the best parts on it, even if it means waiting to save the money, i want it done right, and this message board is deffinatly an outlet for making a badass camaro.
Old Sep 1, 2004 | 07:58 AM
  #25
XcYZ's Avatar
I'd leave that motor in it for now and start accumulating all the parts for a complete new motor. When you have everything, assemble it and swap motors.
I'd HIGHLY recommend a 406 with the best heads you can afford.
Old Sep 8, 2004 | 09:32 AM
  #26
69ss's Avatar
Any ideal of what times your currently running? It would be nice to have a basis to start with. There is always the 150 hp the easy way..........NOS. But it wouldn't hurt to have some forged pistons in there.
Old Sep 8, 2004 | 09:58 AM
  #27
AP Engineering's Avatar
You can give us a call and we can work up some different packages for you. Depending on how fast you want to run we have a few different packages.
Thanks,
Old Sep 8, 2004 | 04:25 PM
  #28
MikeRock's Avatar
At the moment its sitting, i got pulled over, and the police told me they would give me a ticket if they saw me drive it again, long story short, i need new headers and exaust first... i guess its just a little too loud for them.
As for what times im running, i have no idea. havent been able to bring it to the track yet, but if i were to guess i would say low 13's high 12's???
And ive decided i don't want to do nos, i just want pure unadultarated power.
But as far as a build up i will keep you guys in mind too, getting new heads, pistions, rockers, cam, get it ported.
It will be a while, but thats what is going to happen first and foremost.
Old Sep 11, 2004 | 07:53 AM
  #29
HeavyChevySS's Avatar
Well that sucks, getting pulled over by the cops!
You say your car right now is running low 13s, high 12s....well that's not too bad considering your car would need to put down around 300 RWHP (or close to it) to run those times. That is alot more power than a miild 350 would do. Maybe your under-estimating what you have now.
Either way, you need to open that engine up, find out the condition of the internals and what the compression ratio is and what cam is in there, etc.
As stated in a previous post, buy the best set of heads you can afford then match the cam and compression to head flow data (don't forget about stall speed and gears and etc).
You asked about a stroker...It's really not hard to build a 450HP stroker (383-385). Major ingredients....10.5:1 short block, medium sized cam (230ish duration), and a good set of heads (Pro1 or AFR or Brodix are the only ones I would use) will get you close if not more than 450.
Good luck with your decisions...
Old Sep 14, 2004 | 08:08 PM
  #30
406TA's Avatar
Low 13's, high 12's is damn respectable if those times are accurate. Many people overestimate what their car runs (and what it has for HP). It seems like everyone I run into says their mild 350sbc has 400+HP and runs 12's!
Get it to a track and see what she does. Good luck!
Black93lt1
Nov 21, 2014 07:30 PM
Red89GTA
Sep 13, 2003 10:00 AM
WickedFast555
Advanced Tech
10
Oct 27, 2002 10:09 PM
