Cannot Decide On What CAM!!!
SO you think that I would benefit more from a 212-218 range duration cam, then the xe 274 (230/236)? I just dont see how the smaller cam will run better and produce more power than the 230/236
Reread the whole thread. It's a heavy car and you have an automatic, don't want to run a lot of gear or rev it much past 6,000rpm. We are talking about making midrange power, not peak power. You are also running a carb and if you don't have a decent vacuum signal, it will run like crap at low engine speeds.
IF you are willing to run more gear and a looser converter, you should use a bigger cam (and a single plane intake).
Rich
Rich
Lt1son
Dec 31, 2014 01:35 PM
