Question about Gauge Cluster 1980 Camaro
Old Jun 10, 2007 | 05:49 PM
rwjohnson06's Avatar
On an original 1980 Camaro, what is the ohm scale which the original fuel guage operates on? Thanks in advance for any help.
Old Jun 10, 2007 | 07:52 PM
angel71rs's Avatar
I think most GMs after the late 60s worked with sending units that were 0 ohms empty, 90 ohms full.
Old Jun 10, 2007 | 08:04 PM
CamaroRS_SS
Guest
Posts: n/a
The sending units are pretty reliable, usually it is a fault somewhere in the wiring. The usual suspect is a bad ground commonly caused by corrosion. Have you traced your wires from the tank to the instrument panel?
Old Jun 10, 2007 | 08:52 PM
I recently installed a full vehicle wiring harness, and tail end is my next step. My stock fuel guage works... idk how acurate it is lol... but who cares 20 gallons on a 10mpg car ur fillin up ever 4 days anyway. haha. I was swappin out the stocker dash for a pro comp setup and dont know which fuel gauge to purchase due to the 3 different ohm ranges you can purchase. I ran by a Chevy Truck page which mentioned a 240 - 33ohm sender, but I want to make sure and have something absolutely confirmed for my 80 Camaro. Thanks again.
Old Jun 10, 2007 | 11:02 PM
By the way the here is the page for the three ohm setups, maybe itll help. "http://egauges.com/vdo_mult.asp?Type=Fuel_Level&Series=Pro_Comp"
Old Jun 14, 2007 | 12:44 PM
11secgen's Avatar
Zero When Empty.
cmdeshon
Dec 27, 2014 10:06 AM
Joes96z
Dec 13, 2014 07:48 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
