BUILD UP what to do on a budget
Old Dec 6, 2006 | 09:08 PM
  #76
Dave89IROC's Avatar
if you want to stay Eagle, contact them and see if they have or can build you a kit
Old Dec 6, 2006 | 09:14 PM
  #77
Dave89IROC's Avatar
356-B13005E+040 at jegs will give you ~10.7:1 CR with those heads
356-B13004E+040 about 9.5:1
{tip, at Jegs, the +40 on the end of the eagle kits means .040 oversize on the pistons)
Old Dec 7, 2006 | 05:28 PM
  #78
rob97ss's Avatar
Originally Posted by 67speeda
okay going to stay with the 327 and just do a better top end swap. need sugestions on what to get. whould that summit kit by trickflow still be good?
any ideas on what heads and cam to get, please post. 2500 is about my limit.
this spring/summer i will put a blower on it
I'm no expert,but i think you really need to figure out what you want to do first, N/A,NO2,blower?It woundnt be a good idea to build a 10-1comp motor and down the road just throw a blower on it,thinking it going to make more power.jmho.
Old Dec 9, 2006 | 09:42 AM
  #79
User56898's Avatar
I have put a lot of thought into it...
I am going to stay N/A and put spray on it for the few times i hit the track. this is why i wanted the forged internals. max shot will be 125-150
goal for 1/4 time is solid 11 sec car. 11.4-11.6 sounds good.
going to go with the kit on jegs that gives me ~10.7: CR
Old Dec 9, 2006 | 10:02 AM
  #80
User56898's Avatar
356-B12008+040 and 356-B12012+040
what is the advantage of going with 6.0 inch rods over 5.7inch rods?
Old Dec 9, 2006 | 10:38 AM
  #81
jerminator96's Avatar
With a 5.7" rod you will have an extra .3" of piston. I'd say that will help you with surviving the nitrous.
Old Dec 9, 2006 | 08:18 PM
  #82
User56898's Avatar
good because thats what i just ordered lol
thanks everyone for all the help
hopefully i can get the rest of the money to finish the build soon
Old Dec 10, 2006 | 12:39 PM
  #83
byrons1502's Avatar
summit sells a kit for your application it is a 69-79 chevy small block 350. if you go with a 383 kit the year of your crank and internals are not important. if you have never built an engine before i recommend buying some books (alot of books) and do some reading before making up your mind. you can easily wrap up over $500 in tools to build a engine CORRECTLY. you might be better of buying an engine with a good warranty for your first time. gm sells a short block that can easily handle 500-650 WELL TUNED
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
CARiD
Sep 30, 2015 05:44 AM
pepon214tx
Sep 20, 2015 04:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
