rattling
Old Aug 16, 2010 | 10:09 PM
Chris7374's Avatar
Exclamation rattling
i just put my subs in today and my back hatch rattles like hell, is there anyway i can keep it from rattling?
Old Aug 17, 2010 | 08:58 AM
Chevyssoccer's Avatar
find specifically where it is rattling and stop it. check the plastic fender covers (specifically screws), jack and handle, license plate, gas door...
Old Aug 17, 2010 | 09:21 AM
Chris7374's Avatar
sounds like its coming from the spoiler or the hatch itself
Old Aug 17, 2010 | 09:28 AM
razor02097's Avatar
From outside the car with the music playing try to isolate the rattle by placing your hand on various parts such as the hatch, spoiler, license plate, gas door, glass, tail lights, berger panel, etc.
If it isn't on the outside then you will have to start on the inside.
The spare tire area is like an echo chamber... it is very open and there is no insulation or sound deadning at all. remove the spare and jack to see if that is it. If not then remove some of the paneling Once you find what it is then you can install sound deadning material or tighten fasteners to make it stop.
Old Aug 17, 2010 | 09:44 AM
Chris7374's Avatar
thanks ill try that. is there anything i can use to deafen it besides stuff like dynamat? because that stuff is really expensive
Old Aug 17, 2010 | 09:53 AM
razor02097's Avatar
Check for tar based adhesive heat shielding material... they aren't as thick and don't deaden as well but they are about half the cost most of the time.
Old Aug 17, 2010 | 09:57 AM
Chris7374's Avatar
where would u find these?
Old Aug 17, 2010 | 10:04 AM
razor02097's Avatar
most places that sell performance parts. Most times it is used for wrapping CAI, shield fuel lines from exhaust pipes, keep heat from damaging the hood's paint, etc.
Old Aug 17, 2010 | 01:02 PM
Chris7374's Avatar
found out its the taillight covers thats making the most noise
Old Aug 17, 2010 | 01:07 PM
razor02097's Avatar
as in black out covers?
Maybe sell them and tint your factory covers
Old Aug 17, 2010 | 01:13 PM
Chris7374's Avatar
no my factory ones
Old Aug 17, 2010 | 01:15 PM
razor02097's Avatar
If it is the housings you can buffer them with foam washers, if the covers are separating from the housings you will need to reseal them with RTV adhesive
Old Aug 17, 2010 | 03:02 PM
Chris7374's Avatar
aight thanks
Old Aug 17, 2010 | 05:42 PM
Chris7374's Avatar
whats rtv adhesive?
Old Aug 18, 2010 | 07:23 AM
razor02097's Avatar
something like Permatex... you want something to seal as well as hold the part together. There are other products that will work also
autoxr166
Sep 25, 2015 04:21 PM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
TheV6Bird
Oct 31, 2002 06:37 AM
'01BlackZ
Aug 4, 2002 01:44 AM
