Hardwire Garage Door Opener???
Old Jul 17, 2005 | 12:00 PM
johnnyb's Avatar
I have plans on doing this, but i don't exactly know how (actually where) to wire it up. I have read about people hooking it into the high beams, but i use my high beams alot so i can't hook it up to that(i don't want it to be switched on all the time). I am thinking that i would somehow be able to wire it into the cruise control switch but i am not sure. I know that i could probably just wire up a new switch, but i would rather just use something already on the car. It also has to be something with switched power because i only want it to work with the key on. Has anyone done this? Any suggestions?
Old Jul 17, 2005 | 08:19 PM
ROCKN SS's Avatar
Re: Hardwire Garage Door Opener???
I added a switch for mine, I already was putting in some switched for my alarm system so I just threw in one more mini momentary toggle switch. I put the opener itself just under the top of the dash. I hardwired the button closed and used a pair of resistors for a voltage divider (wired to the toggle switch and 12 volts) in place of the battery. Works fine.
Old Jul 17, 2005 | 08:38 PM
johnnyb's Avatar
it looks like i may just add a switch, but i would rather run it off of a switch that is already in the car...
Old Jul 18, 2005 | 04:18 PM
johnnyb's Avatar
does anyone know if i would be able to hook it up to the button on the cruise control? (the decelerate button)
Old Jul 18, 2005 | 08:29 PM
johnnyb's Avatar
im going to start this project tomorrow...so any other input????
Old Jul 20, 2005 | 01:52 PM
PentaVolvo's Avatar
should be possiable u just have to find the right wires
Old Jul 20, 2005 | 02:26 PM
johnnyb's Avatar
yeah i got it to work. i just used the wires off of the "valet" button from my alarm that i have hidden in the ashtray.
Old Jul 20, 2005 | 08:02 PM
chuckd4more's Avatar
But now it is hidden no longer.
DirtyDaveW
Dec 1, 2016 05:37 PM
Heathen1
Jan 2, 2016 04:27 PM
97z28k&N
Jan 9, 2015 04:58 AM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
bernie1951
Dec 10, 2014 10:03 AM
