View Poll Results: What is the MOST weight you would ACCEPT in a Camaro coupe.
3,800 lbs
13
12.75%
3,700 lbs
16
15.69%
3,600 lbs
44
43.14%
3,500 lbs
18
17.65%
3,400 lbs
11
10.78%
Voters: 102. You may not vote on this poll
Ummmm.....about weight....
Old Jan 4, 2006 | 01:40 AM
  #76
teal98's Avatar
Re: Ummmm.....about weight....
IRS, more structure for safety, side air bags, stability control, nav systems, 6 speed automatics, stronger drivetrains for 400+hp and torque. If they can get it under 3700, I'll be happy.
A G35 coupe weighs a bit over 3500 pounds, and it only has a 270ft.lb. (old rating system) V6. If GM can put essentially the same features into a similarly sized but less expensive car, and add a 400ft.lb. V8 while adding less than 200 pounds, we should cheer!
randy161984
Apr 10, 2007 03:09 PM
