View Poll Results: What is the MOST weight you would ACCEPT in a Camaro coupe.
3,800 lbs
13
12.75%
3,700 lbs
16
15.69%
3,600 lbs
44
43.14%
3,500 lbs
18
17.65%
3,400 lbs
11
10.78%
Voters: 102. You may not vote on this poll
Ummmm.....about weight....
Re: Ummmm.....about weight....
Originally Posted by Doug Harden
OK....I haven't swung at this dead horse yet, so here's my question.....
With a live axle, we had a panhard rod, two lower control arms, a torque arm, heavy axle assembly....with an IRS setup, we have a couple more control arms...no panhard rod or torque arm...and the center sections are nearly the same...of course both have brake assy's....
Substitute 18" or so of 3" dia. X 3/16" wall tube and 1 1/4" dia. axle shafts on two sides, for two small axle shafts with CV joints....just what exactly adds 150 more pounds over a live axle?!?
On a live axle car, the solid axle (which as you point out weighs about the same as the IRS) serves as it's own rigid structure.
On IRS (save the one like on the GTO, which depends on relatively heavier and larger arms to support the suspension than those on a live axle) you are going to need a "cage" to hold the IRS system, and bolt the whole unit (IRS & the structure holding it) to the chassis.
As for the chassis, the area where it's going to be attached is going to have to be reinforced, since istaead of keeping the live axle located, it's going to have to firmly secure a heavier sub-structure.
Mustang Cobra & GT are perfect examples of what to expect since it's a unibody car. Any IRS system in a Uni is going to be modular, an assembled mini structure containing the IRS. This is what Sigma, LX, Mercedes, and most other unibody cars use. The GTO and the former version 3 series used the lighter system from paragraph before last.
Corvette is not a good example of a lightweight IRS. First, it's a full frame structure, second GM went to extremes to trim weight from the car, and third GM has a higher profitable pricepoint on the car.
The argument would then move to "Well, you'll sell more Camaros than Corvettes to make up for the pricepoint difference." What fails here is that it costs more to make the IRS than a live axle. More labor intensive, more parts, more bushings. Any doubts, sit a live axle assembly from a Mustang GT next to one from a Cobra. In short, though engineering costs will be spread around better, it's going to cost more per car to make than a live axle due to labor and parts. This is offset by more use of steel.... which equals weight.
From there, the next example of a lightweight inexpensive IRS that's going to be brought up is the Kappa chassis. However, this isn't a good example either. The Kappa is as long as a Miata, yet weighs 3000 pounds. It would have been alot heavier if GM hadn't eliminated all the power options, added in the V8 and all the components that could withstand the horsepower & torque the engine would make. Also remember, a 4 cylinder Pontiac Solstice is only about 150 pounds lighter than the 2 feet longer, far more electric motor and electronics laden, V8 powered, heavy duty transmissioned, heavier duty drivetrain, Corvette.
No one has yet come up with an explanation (plauseable or otherwise) as to WHY an automaker with armies of engineers, computers that would put the ones at the pentagon to shame, CAFE and more stringent safety standards brething down their backs, would purposely create a heavy IRS system if it could make a light weight one without costing itself any additional money.
Summary;
1. If you want IRS, it's going to cost weight or money.
2. GM, Ford, and Chrysler aren't BMW or Mercedes.
3. GM, Ford, and Chrysler all have smarter people working in engineering than any of us here.
4. These cars need to be engineered to sell at prices people expect.
5. You simply are not going to get a $50,000 BMW 5 series suspension on a $20,000 Chevrolet.
6. Finally, that we are getting more difficult and sophisticated IRS on US made RWD cars, but then to think that engineers at Chrysler AND Ford AND General Motors are too dumb or are going to ignore some low cost light weight way of manufacturing them is really, really, really wrong.
Chrysler LX weigh 4100 lbs. Cadillac's STS weigh 4300 lbs. The VE is going to weigh about 4000 pounds. All are about the same size.
GTO and Mustang Cobra both weighed about 3750 pounds. Both were the same size.
If we get a 6.0L V8 Camaro the same size as the Mustang, with IRS, priced in the mid $20Ks range, and weighing even a pound under 3800#, we should line up to buy the engineers steak dinners because they would have done a HELL of a job.
I suppose this is about as a in depth an answer possible without drawing pictures or a field trip to a local junkyard.
Please tell me how little ol' Mazda pulled that off? I'm not saying GM didn't do a nice job with Kappa, but I don't understand your point at all. In fact, you've just muddled things.
Primarily, the sub-frame that the whole IRS is attached to.
True, an IRS sub-frame adds weight. Of course, you don't have to have one, but it is generally preferred for NVH reasons.
But this sub-frame isn't dead weight - like, for example, that heavy cast iron live axle housing which IRS does NOT have BTW - it also adds structure and rigidity.
The smart platform architect will quantify this in his structural analysis and reduce mass somewhere else because of it.
25-50 lbs. I stand by it.
But yet somehow they came to the conclusion that a 7.5inch 2 spider 10 bolt was a good idea. They could have used the 8.5 inch 10 bolt they had been making for years. And any idiot could tell you 4 spiders are alot stronger then 2, but yet even with all their computing power and engineers we got a 2 spider 7.5inch 10-bolt.
Point. Just because they could do something, just because they should do something, doesn't mean the will do something.
Which brings us back to the real point which was done in a thread not too long ago here. Safety and comfort items add ALOT of weight!
The 150 or so pounds of an IRS is insignificant when you realize 2 power bucket seats and wiring add that much to a car alone. Power windows also add up to 40 pounds, AC is probally another 150 pounds+ alone.... and these are things people demand as standard today, not options like they did back when the 3rd gen came out!
I still have most of the parts and a bathroom scale.
BTW: Although I prefer something around 3200 pounds, as long as the new Camaro is quicker, better handling, better made, and reasonably priced, I'm not worried about the weight. If I was, I'd buy a Miata...... but then, I wouldn't want to be T-boned in one.
Their is a reason why the new Z06 does so well in performance, because they rerally focused on making the car lightweight. Hopefully they will take the same concept and apply it towards the new Camaro.
Originally Posted by 94LightningGal
I believe that curb weight is based on the absolute basic car, dry (no fluids), without option one. Everything I have seen from the Corvette sites, says it weighs about 3350lbs.
Look at it this way, if the base Vette only weighed 3179lbs............ then the Z06 weighing 3150lbs is not much of an accomplishment.
Remember, the Solstice weighs 2900lbs............ and it is a tiny, 4cyl, 2-seater sportscar.
Some of you guys seem to forget that even though the new Z06 lost a lot of weight (vs. base C6) it also gained a lot of racing gear making it heavier.
Items that add weight pounds
Upgraded brakes 27.6
Dry sump, extra oil, oil cooler 23.1
Three-inch exhaust and valved mufflers 11.7
Larger differential with cooling circuit 11.0
Rear-mounted battery
(cables and bracket) 8.8
Larger wheels and run-flat tires 6.2
Items that subtract weight pounds
Aluminum chassis structure 136.7
Reduced interior content*
*(electric seat bolsters, six-way passenger-seat adjustment, acoustic damping material) 33.0
Magnesium engine cradle 11.9
Removable roof hardware 6.6
Carbon-balsa floor panels 5.3
Carbon-fiber front fender liners 2.2
Originally Posted by blckbrd84
Umm Chevy's site lists the curb weight of a standard Vette at 3,179 lbs.
Although I will agree that I can't see a 4-seat affordable ponycar (assuming at least SOME interior room) at only 121lbs more.
Chris
Chris
Shipping weight is a basic way to look at "drag racing" weight. All fluids topped but just a couple of gallons of gas. My 2002 Z06 had a shipping weight of 3040 pounds. A 2006 Z06 2LZ is a 3078 pound shipping weight. Gasoline is heavy.
Originally Posted by 1fastdog
GM rates curb weight "wet". Full fluids including gas tank.
. If it were dry, they'd call it "dry weight", but it's not ... it's the weight at the curb! On the road!!
It does almost seem surprising about the weight of the Solstice though
. Granted it's a convertible, but so is the Miata?
Who knows
Call me a NVH obsessor but I'd much prefer they left the dampening material in the Z06. That's one thing I am not happy to give up to save weight.
I'll go on a diet before I'd want to make the car louder.
I gather the Z06 drivers wouldn't ever turn on their radios because they all want to listen to 7.0L of glorious symphony... hence the reason they omitted the NVH stuff.
Originally Posted by SSbaby
You Lexus drivers, you!
