Problem i see in 5th Gen camaro (HP related)
Re: Problem i see in 5th Gen camaro (HP related)
Originally Posted by CLEAN
1996. Camaro SS had more hp than base Corvette. And I believe Firehawks had more power than the base Vette every year they were available until 1997.
Firehawk was under a different Brand name, also wasnt out of factory numbers. thats After SLP tweaked it, and still so it was by 10HP which im sure the vette woulda discredited on a dyno. Again, marketing.
joe Public doesn't buy Corvettes. Joe public doesn't wander into Chevrolet showrooms and choose Camaro over a CORVETTE based on sticker prices. If you want bang for the buck, you buy a Camaro. If you want a Corvette, you buy a Corvette.
430hp seems safe enough a guess to run with a Shelby. If they can't make up 30hp by then in efficiency improvements, they can just bore it to 6.2-6.3L.
True, but what Chevrolet car is available to put the LS2 into if Chevrolet had wanted to? Exactly
I'll give you the 96 SS with 305hp but keep in mind the LT4 (330hp/340tq) was put behind all y body six speeds that year.
Originally Posted by FutureZMan
There will Not be a 2007 Camaro carrying the same HP rating as the vette, im sorry but there base model vette will not be challanged on paper by a 13,000 less CamaroZ28
I love the corvette name plate, but its not worth 12,000 to me. I'm beyond positive i would get 80% of people to agree.
And to your arguement about the other 400HP contenders out there.
GTO - Ponitac, and performance wise isnt in the same class as the vette.
CTSv- Cadillac, and is set more at the BMW's and other Euro Touring cars, aslo isnt in the same performance bracket as the Vette.
STSv- Cadillac, same as CTSv.
SSR- is a 15second truck, meant for nestalgia and retro enthusiasts. Shouldnt even be in the comparison.
Trailblazer SS- How did this even get in the comparison.
Camaro SS had 5 more HP, which im sure was just as a ploy for launch. Also the big deal that year was the LT4 Corvette, which GM was trying to shove on the public. Just clever marketing, nothing more.
Not sure why you're hating on the SS and Firehawks, as they were RPO's for the Camaro and Firebird, not aftermarket tuner cars, but whatever.
Hope to see you at NAIAS '06! You may find some interesting CARS there.
Originally Posted by Stewie
If the GT500 comes at 450hp I highley doubt we will see a competitor from the factory.
Hence the "detuned" ls2 w/395hp.
Exactly.
On paper no, but in the real world....go check out some dynos of stock F bodies vs stock LS1 C5's. Fbods have had Corvette power since 1998.
That's your opinion, but I'm gonna have to assume that the 230,000 or so people who bought C5's, that had more or less the same hp as LS1 Fbods, would not share that opinion.
If it where advertised "Camaro this year has a Industry leading 450HP! as does its elder sibling the Corvette!", some potential Y-bod purchasers would consider the Camaro over the Y-bod, it is an opinion but one that could be proven easily.
Just because Chevrolet doesn't have a car currently that can handle LS2 power doesn't mean that will always be the case. GM is seemingly putting Corvette sized power in ANYTHING AND EVERYTHING that can handle it. Do you truly believe that when a new Camaro comes out, that Chevrolet would limit it to 350hp, giving away 100 hp to the Shelby?
Firehawk is under a different brand name, so chevy doesnt have as much sway as they would over the Camaro SS. So 10HP over the Vette is a very realistic estimate for Top brand bird.
and i hope to see you as well at nias
, bring some water as im hoping to feint when i make it to the chevy booth! (for good reason's
FutureZMan, much of your information on this page is skewed. First off, and 01 cobra did not cost $34k, they cost $28k, and it isn't worth mentioning base because they only came loaded. I don't think you are including the Mach 1 and Cobra for the simple fact that stock for stock, a Mach1 is almost as fast as an LS1 F-Body, and an 03 cobra is down right much faster. I know they came out a model year later, but they also came out as early releases for that model year(especially the cobras.)
Second of all, it has been brought up that the 96 SS did have a higher HP rating than the base vette (which I totally forgot), so there is a precedent of it happening, and it is worth noting.
Third of all, about the f-body dynoing less than the vette, you need to get up to date with the ls1 powered f-bodies. The LT1s I can't account for, but LS1 powered f-bodies dyno the same as vettes, sometimes even more due to the solid live axle having less parasitic drain on drivetrain HP. 310 crank HP z28s don't turn 12s stock, yet somehow it happens. Ever work on a Camaro LS1? It is strangely identically to a Corvette LS1, with very few exceptions. No real differences between the SS and z28s either, except for hood/spoiler and wheels.
Lastly, the z06 was designed by GM to be the top dog Corvette, not to run with Saleen Mustangs. The Cobra R came out the same year, and had its thunder stolen by the z06, but something tells me the z06 would have been built anyways, considering 1 in 4 vettes was a z06, and they only made 300 Cobra Rs. It is apparent by those numbers the z06 was designed to be built for volume, not some barely street legal race car.By the way, there was no 01 Cobra R, they were 00 models.
The GT500 would be more in line as a new Mustang Cobra (and I think it should still be called that), so why not at least consider a Camaro competitor for it.
Since this thread is mainly speculation, here's some more in regards to 2008 Corvette/ZO6 HP.
Originally Posted by falchulk
I disagree with a lot. First the Cobra SHOULD be able to be a Camaro. A Camaro with a V8 should NOT cost 40k or be build to order. A mustang GT is sure as hell not a 15 second car!! Mid 13's.
Ive been at many dyno runs where year for year the vette has pulled a 10-25RWHP off of an equal F-body. More so the 1993-1996's, but even on the occasion of a LS1 Fbod Vs Ybod, in some cases i seen a 25-35 difference in RWHP on the dyno runs.
Alot of those people bought just for the fact of having a corvette, but there a good sum of people (alot of which ive encountered) who think just because its a vette' it was going to whoop on my F-body. This is the message GM push's through, the Corvette is unarguably Chevys flagship and as such is portrayed as the best Chevy has to offer. Most Vette' Hardcores, refuse to mention Camaros and Vette's in the same sentence.
Honestly, for someone who didn't know you couldn't get an L98 with a stick, you sure are set in your beliefs about the way things are in Camaroland.
Lets get more to the point. We want the halo camaro to be better than the halo mustang so we can claim our e-penises are bigger. So let us hope that corvette has 450hp by 2008+ or that the v8 used is way more underated than the LS1 was.
Originally Posted by NewbieWar
best I've seen at the tack is a 14.3 and I've seen probably a dozen or so go at it all day
I seen one hit 13.3, i asked him what he had done if at all, he responded gears , exhaust , and a 50shot i beleive.
and a few of the guys that where running them, where camaro owners i know locally and they run them cars damn well, so i wont be blaming it on driver-error.
