Gt500: Loses weight, get's faster avoids gas guzzler tax.
Old Feb 15, 2010 | 11:17 PM
  #121
detltu's Avatar
Good news for Mustang fans.
Amazing that ford built a 550 hp car that weighs basically the same or less than the 426 hp Camaro. If I weren't so attatched to the Camaro nameplate and the looks of the new Camaro I think I would have to buy myself a mustang.
  #122
SSbaby's Avatar
Originally Posted by 96_Camaro_B4C
It seems to me that this is reinforcing my point.
Actually, that article doesn't imply anywhere that the track brakes are any larger than the standard brakes. It says they are solid instead of slotted (interesting, since the whole slotting / cross-drilling idea was cooling, I thought), and I assume they use a more track-friendly pad compound. But it doesn't say anything about going to a larger wheel to clear these same-size brakes. The CTS-V has 19" wheels standard. It may be that they needed 19" wheels to clear the brakes. But those are the standard sized brakes and wheels. It was the previous generation CTS-V (with smaller 14.x" rotors) that had 18" wheels. When did I say otherwise that you needed to correct me?
Anyway, obviously when you go to extreme brake sizes (for bragging rights or performance or whatever), you will need the wheels to be able to fit over them. I mean, you aren't going to fit a 14" rotor and caliper assembly inside a 15" wheel. But the Camaro most certainly does not need 20" wheels (or even 19" wheels) for the brakes it has, which is what started this whole discussion.
As for these track brakes on the new CTS-V, they sound pretty awesome. I would imagine that it is actually the pad material that allows the brakes to work even better when they get a little heat in them. The fact that the bigger rotors are solid only means they are cheaper to make than slotted versions while still providing good heat dissipation.
As an aside, this was actually a problem with some other cars that had early implementations of carbon-ceramic brakes. They were stupidly powerful, but only after they got some heat in them. The first few applications were often noisy and less powerful than expected, with unsatisfactory pedal feel (again, until the temperatures elevated some).
In regards to me having to correct you... yes you did say previous CTS-V had 18" wheels but it's what you didn't say that needed the correction to your views - the 19" wheels are needed for serious performance cars on the heavy-ish side like the current CTS-V. The fact that this car is equipped with 19" wheels proves my point about rotor size and functionality relating to bigger wheels, does it not?
Yes there are cooling benefits to cross-drilling but cross-drilled rotors have durability issues ... the rotors are prone to cracking and exploding! In regards to the solid rotors on the CTS-V, they are cheaper to make than the slotted rotors while still providing the benefit of good heat dissipation afforded by larger rotors.
Bob intimated that 19" and 20" wheels didn't provide additional functionality - I supplied 'some evidence' that it does. Didn't you agree entirely with Bob's statement... which has ultimately led to this expanding discussion, not just about Camaro?
You are right that Camaro doesn't need 19" or 20" wheels but that doesn't mean Camaro won't use bigger rotors for a track pack version using the same brake package as the CTS-V, though, does it?
Old Feb 16, 2010 | 06:20 AM
  #123
Bob Cosby's Avatar
Originally Posted by SSbaby
Yes but did you not imply that 19" were also "BIG" in your opinion? To that end they are there purely for design purposes only - you did indicate that did you not?
I'll do more than "imply" - I think 19" wheels certainly are "BIG", in my opinion, and that they are purely for design purposes only. Isn't that the point I was attempting to make?
Yes, you could fit 14" rotors under 19" wheels but so what's the big deal about going one size bigger? Don't tell me it's all about weight?
Could you not fit them under 18" wheels?
Using your logic of "what's the big deal about going one size bigger", then you would never get to a wheel size that is "too big".
To each their own. For me, given that I don't feel the need to walk in lock-step with my favorite car maker, I can express the opinion that xx size wheel is "too big". 18" is a good point for me (no matter if we're talking the Camaro, Mustang, or whatever). For you? I don't know....22"? One size bigger? One size bigger than one size bigger? Whatever GM wants to use?
I think that last one probably hits the closest to home.
Well blow me down. It took this long for you to admit that. Shocking.
Old Feb 16, 2010 | 07:08 AM
  #124
ZZtop's Avatar
Originally Posted by Steve0
I would also be one of the few on here who would rather have a GT500 than a base Vette.
I would also take a GT500 over a base vette. Its more unique, a great cruiser, and can take the wife and (future) kids to the movies, get ice cream, etc.
Iv'e seen some nice low mileage, one owner 07's and 08's for $31-32k recently. Thats a pretty darn good deal.
Old Feb 16, 2010 | 07:09 AM
  #125
96_Camaro_B4C's Avatar
I think you actually quoted me there, Bob. I was the one agreeing with you.
But SSbaby did eventually agree with that statement (which perhaps you meant to quote):
SSbaby, as I said, of course if you go to extreme brakes, you will need wheels big enough to clear them.
But that is not what has led most newer vehicles to have such mondo size wheels. The Ford Edge Sport doesn't even need 18" wheels to clear its brakes, let alone the monster 22" wheels it actually uses.
The Chrysler LX cars do not need 20" wheels to clear their brakes, but they got them. Why? IMO, because the styling of the cars is so "thick" / "blocky" that it needs the bigger wheels to look right. They look OK on the 18" wheels that the standard cars have, but 20" wheels actually look correct for the styling. I don't think they provide one iota of increased functionality for those cars.
The general trend is about styling, not about clearing pizza pan brake rotors for the 0.0001% of the driving population who drive their cars on road courses. That is certainly the case for the Camaro, which, again, is what this was about originally.
EDIT: Plus, I still want clarification about your claim of fixing understeer by fitting bigger brakes...
Old Feb 16, 2010 | 07:29 AM
  #126
Bob Cosby's Avatar
Eh....it was early, and I really should have known better than to think he'd actually say that.
Thanks for correcting my screw-up.
Old Feb 16, 2010 | 05:16 PM
  #127
SSbaby's Avatar
But SSbaby did eventually agree with that statement (which perhaps you meant to quote):SSbaby, as I said, of course if you go to extreme brakes, you will need wheels big enough to clear them.
Joe
Forget what the argument was originally about. It took a detour when you agreed with Bob's comment regarding anything over 18" wheels is not needed. I don't believe I've digressed from arguing this exact point.
I have proven to you both that there are in fact cars that require brakes with the necessary clearance for wheels larger than 18". If you want me to give you examples of rotors needing 20" wheels for clearance, forget it, I can't. The fact that I used such cars as the current CTS-V, HSV GTS as facts (this is what Bob requested, btw) is proof that 15" rotors are being used for necessity and not for looks.
My simple rule is diameter of the wheel minus 4" as the maximum rotor size allowable. On this note, I have not heard of 16" rotors being made widely available for certain production cars.
Let's not just use GM cars to prove my point (just in case you thought I was just another GM fan boy) look at the all mighty Nissan GTR.
In regards to the understeer and brakes... the understeer can be cured with suspension changes. Where that fails to provide a solution - and the car continues to understeer - then you need to look at your brakes. If the car doesn't stop quickly enough or the brakes/tires "go off" then understeer will result if you continue to brake the same distance from the corner as when the brakes/tires were fresh. Of course, having healthy brakes alleviates that problem. I place emphasis on the word "alleviates". Note, I didn't say cures! It just allows the driver more car control, that's all. EDIT: You applied the term 'fixes understeer' to my statement - your wrong.
PS: Thanks for putting 'humble' Bob in his place!
Old Feb 16, 2010 | 05:41 PM
  #128
Bob Cosby's Avatar
Eh, might want to go back and read my original statement. To wit....
Big wheels today are almost totally about style and virtually nothing about functionality.
Do believe I'll stick by that. You provided two vehicles that "require" 19" wheels (to get over huge brakes that are "needed" to stop a "performance car" that weighs over 2 tons). Got it. Even so, I think "almost totally about style" is quite accurate. Certainly it is for the 2010 Camaro.
Disagree if you wish.
Bob
Old Feb 16, 2010 | 05:54 PM
  #129
Steve0's Avatar
Ive been silently watching this thread's battle of semantics since the beginning and honestly have nothing constructive to add other than "I like big wheels."
This thread reminds me of why I try not to debate with people on the internet.
Old Feb 16, 2010 | 06:14 PM
  #130
SSbaby's Avatar
Bob
But don't you agree that if you put bigger brakes on a car and it laps 'consistently' faster around a circuit (i.e. no brake degradation), it's not only a speed/time gain but also an engineering solution to a temperature problem?
It might well do OK with smaller wheels and brakes but at the same time you cannot ignore progress even if that progress means a simpler, cheaper avenue to solving a potential or known problem.
And yes, I do love the HSVs and Camaros with 20" wheels. It suits them perfectly. Although such wheels may look out of place on other cars. I've also seen 300Cs with 22" wheels and, no, that's not for me!
Anyway, I've made my points. If I continue with this discussion, I'll just be regurgitating everything I stated. And yes, I can accept that others do disagree with my views.
Old Feb 16, 2010 | 06:15 PM
  #131
Bob Cosby's Avatar
Bah. Where's your sense of adventure and thirst for cheap entertainment?
Old Feb 16, 2010 | 07:46 PM
  #132
Z28Wilson's Avatar
I don't know about all that, but I do know it creates a problem with increased rolling mass....
I don't think it's any coincidence that brake packages have gotten bigger and bigger as cars of this ilk have gotten heavier and heavier....
Old Feb 16, 2010 | 08:17 PM
  #133
SSbaby's Avatar
And what evidence can you provide in that it causes more problems than it solves?
Or is "more mass" just a dirty term around this neck of the woods?
Btw, I hear the difference between similar spec 19" and 20" wheels is around 4kg (10 lbs) per wheel.
Old Feb 17, 2010 | 06:02 AM
  #134
Bob Cosby's Avatar
If that were the only change, sure. Which car in particular are you referring too?
Bigger wheels are progress? Just one size bigger? Just one size bigger than one size bigger? Does it ever stop? We've heard a lot around here about "diminishing returns" when it comes to consistently adding more HP to go along with more weight. Do we get to the same with bigger brakes to go with more weight?
I pretty much don't like them on anything. But that's a styling question, and thus extremely subjective. Let me say this again - 19" and 20" wheels on Camaro are purely for style and not function.
Wait - isn't that where this started? Hehehe....and we can play semantics, if you like (Steve might have issues with it though ).
Looks like you may have done something new vice just regurgitating below, but ok.
Have a good one.
Bob
Old Feb 17, 2010 | 04:55 PM
  #135
SSbaby's Avatar
Yes, it will stop when the cars stop growing in size and weight. Until then, progress is progress, design is design, and engineering is engineering. You earns your money, it's your choice whether to embrace the change or not.
Different strokes for different folks as they say.
