GMT900 5.3L V8 = 355HP/380tq
Re: GMT900 5.3L V8 = 355HP/380tq
Originally Posted by Threxx
Same reason people bow over ricerlicious small displacement 4-cylinders that put out 80hp liter that still couldn't push a 2800 pound car faster than a 7 second 0-60 time.
I've always been annoyed by those who focused on that at all.
My Lexus GS400 made 300hp/325tq (old SAE ratings of course) with only 4 liters of displacement. I could sit there all day and talk about how impressive that was compared to the 'crappy' LS1 that took nearly 50% greater displacement to create less than 20% greater power. But the truth is the GS' engine also had twice as many valves per cylinder, twice as many cams, variable valve timing, and many other features to its benefit that the LS1 didn't have.
So what we have here is two motors - in the end I only care about four things:
The actual power curve
Noise, vibration, and harshness from the motor
Reliability
Fuel efficiency
(and maybe a fifth that indirectly affects the price paid for the car which is the cost of development and production)
The rest of it is for engineers to learn from and ricers to quibble over.
Reliability
Fuel efficiency
Originally Posted by teal98
If someone knows, they haven't told yet.
haha. Let me know when you guys figure something out here then.
Originally Posted by MarineReconZ28
Well shat. What are you guys debating then?
"old SAE ratings"? Since when did Toyota follow the old SAE ratings? Yes, the SAE rating method was revised, but Toyota (& Honda) didn't follow the old standards: they used their own, proprietary (& unorthidox, IMO) methods - which is why virtually everybody else didn't suffer the hp drop when the new SAE standards were adopted.
And as my final comment to this thread.
The GR-FE 4.0 makes more torque and more horsepower at almost every point along the power curve up until somewhere after 4000 rpm where the GM motor it makes a few horsepower more.
The Atlas I-5 redlines at over 6000 RPM, so in any sort of acceleration test, the engine would spend most of its time over 4000 RPM, which means that the Atlas may actually do somewhat better than the Toyota even in the "real world".
If what you're looking for is torque/horsepower at full throttle at 2500 RPM (at a fixed RPM, it doesn't matter which metric you use, since you can easily derive one from the other), then you'll want the bigger engine. Note that if you have an automatic transmission, you'll never be at full throttle at 2500 RPM unless you're between 0-10 MPH, as the tranny will downshift.
In the "real world" people spend a tiny fraction of their time (if ever) at WOT in a pick up truck.
They get to Wide Open...
We were pulling a really heavy load awhile back (albiet in an older Ford Diesel so not as much power) and ran Wide Open just to hit 70mph (I65 Speed Limit in IN) and had to keep it to the floor the whole way. 3hrs of Wide Open.
Sure. By extension, maximum power only matters a tiny fraction of the time (if ever), so what's the point?
That is, afterall, the entire reason why pacer made his typical assumption that since it was a Toyota, it must be peaky in its powerband, and then critisized me for not understanding power 'under' the curve.
Power at a given RPM always matters as that affects the overall driving experience. The next question is what given RPM is most important to the average pick up truck driver. I wont' pretend to know the answer to that but I'll go ahead and guess.
To use the two engines that were discussed earlier...
Toyota: 236 hp @ xxxx rpm, 266 lbft @ ???? rpm
Atlas I5: 242 hp @ 5600 rpm, 242 lbft @ 4400 rpm
Those numbers are for WOT only. It isn't like, when you step on the throttle (say 25% throttle), that when you pass 4400 rpm in the I5, you automatically just hit 242 lbft. Those numbers are the peaks available at WOT.
So, if WOT hardly matters to a person in a pickup (which I disagree with; WOT definitely matters when towing/hauling, and when you get on it to merge, etc. - but in "normal driving", hopefully they aren't hitting WOT constantly), then who cares about an extra 24 lbft of torque available at WOT? Say during your normal drive to work, you never go above 50% throttle. So say you only ever see 120 lbft @ 3000 rpm in the 4.0 V6. It isn't like the I5 can't make that amount of torque at the same rpm. Maybe it takes 55% throttle blade opening instead of 50%, for example. Any driveability/feel issues will come down to throttle progression calibrations (i.e. how far the pedal is pushed to get a certain actual throttle blade opening and corresponding torque). Both engines could be set up so that the same amount of pedal travel gives the same amount of torque (but the throttle blade would probably be open a bit more in the I5 vs. the V6). That is, of course, until WOT is achieved, at which point the Toyota would have an advantage until the upper RPM ranges.
It is only under full throttle at the respective engine speeds that one would ever feel the 242 or 266 lbft.
Anyway, ultimately the peak numbers and the speeds at which they are attained (which is what are shown in vehicle/engine specs) DO matter at some point or another, even in pickup trucks. Full throttle accels, towing/hauling, etc. And, of course, for bragging rights. Otherwise, we wouldn't be in the power/torque war that we are in...
I'm not saying the 4.0 V6 isn't (slightly) better suited for a truck application with more torque available at a lower RPM; it probably is. I only made this post because you commented that WOT is only ever an issue for a tiny fraction of the time. I'm thinking maybe there is some terminology confusion when you are trying to answer teal98, or something.
Originally Posted by 96_Camaro_B4C
Right, but if you are not going WOT, then it doesn't really matter so much...
I realize this, but would the resulting power at partial throttle not typically be derived from / closely related to the power at full throttle?
I remember my aunt's 1976 Buick Skylark with 231 CI V6 (3.8 liters in modern terms). The throttle linkage was set up to give you a lot of response with a little bit of travel. So if you drove it and never went past halfway, you'd think it was a peppy car. But then when you used the other half, you'd realize it had already been giving all it had
So I don't think you can define partial throttle in any useful way, except by measuring fuel efficiency at various partial throttle horsepower outputs (or maybe NVH, etc.).
I think you can define partial throttle in any useful way, except by measuring fuel efficiency at various partial throttle horsepower outputs (or maybe NVH, etc.).
Trevor98ramair
Jun 9, 2005 10:16 PM
91_z28_4me
15
May 10, 2005 12:41 PM
91_z28_4me
21
Apr 27, 2005 03:41 PM
