GM Says Volt Has Cost $750M to Develop
It's a revolutionary car, $750M is a pittance compared to what normal new generation vehicles cost to design, develop and manufacture.
The amount of buzz the Volt is generating (pun intended) all over the globe is worth its development money. There's already speculation that the Volt (and/or its technology) will be built in Europe and Australia.
I don't believe it would be quite that simple. Most of the components of the volt are probably specific to the volt. You wouldn't be able to slap this system, without extensive, expensive modifications into another vehicle. It would be easier to put the batteries into a suburban/tahoe/silverado, as there is more ground clearance, and more space in general, but I don't believe the electric motor would produce the power necessary to tow a boat, or even be able to haul a 5k+ lb vehicle, with no payload.
I understand that (now) but it still seems a misconception to call it an all-electric vehicle when you need a gasoline-powered engine/generator on board to charge the batteries.
I can understand that you are getting more mileage out of the gasoline burned than in a traditional ICE powertrain but "all electric" still seems a miss-characterization to me.
Maybe my "confusion" is that I've also heard this referred to as a "Zero" emissions vehicle and I don't see how that can be if you've got a gasoline engine on board (whatever the gas engine is used for).
Nonetheless, you're right, I do think it's technology that should be pretty scalable across car lines over time once the cost comes down some.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
jackpawt883
Sep 10, 2015 08:53 PM
