The BOSS is Back !!!
Old Aug 13, 2010 | 02:52 PM
94LightningGal's Avatar
This is so cool !!!! First, the very cool video.
http://www.youtube.com/watch?v=jfVXB...layer_embedded
THE BOSS IS BACK: 2012 FORD MUSTANG BOSS 302 BRINGS ROAD RACING LEGEND BACK TO THE STREETS
The Boss returns! Limited production 2012 Mustang Boss 302 set to become the quickest, best-handling straight-production Mustang ever offered by Ford, based on the world-class foundation provided by the 2011 Mustang GT
Boss upgraded in nearly every vehicle system; engine output, brakes, suspension, interior and exterior all examined to optimize weight, aerodynamics and track performance
Full Mustang team effort results in a comprehensive re-engineering available only through the factory; new Boss is not a package that can be purchased out of a catalog or achieved through tuning or aftermarket parts
Limited-production track-oriented Boss 302 Laguna Seca model expands on Boss racing aspirations, deleting rear seat and adding race-ready suspension and aerodynamic treatments
MONTEREY, Calif., Aug. 13, 2010 – Ford gave the green light only once before: In 1968, management approved a special Mustang – a car that sacrificed nothing in its quest to be the best all-around road-going performance machine ever created by Ford Motor Company. That car became the 1969 Mustang Boss 302, and it remains one of the world’s most sought-after examples of American performance.
Forty-two years later, Ford has given the green light again.
The team of Ford engineers, designers and stylists – all Mustang enthusiasts to the core – that created the groundbreaking 2011 Mustang GT has distilled a new model to its purest form, strengthening, lightening and refining each system to create a race car with a license plate. Its name: the 2012 Mustang Boss 302.
“The decision to build a modern Boss was not entered into lightly,” said Derrick Kuzak, group vice president, Global Product Development. “The entire team at Ford felt the time was right and with the right ingredients, the world-class 2011 Mustang could support a successful, race-bred, worthy successor to the original Boss 302. For us that meant a production Mustang that could top one of the world’s best – the 2010 BMW M3 – in lap times at Laguna Seca. We met our expectations.”
To celebrate the racing heritage of the new Mustang Boss 302, Ford will also offer a limited number of Boss 302 Laguna Seca models, named for the track where Parnelli Jones won the 1970 Trans-Am season opener in a Boss 302. Aimed at racers more interested in on-track performance than creature comforts, the Boss 302 Laguna Seca has increased body stiffness, a firmer chassis set-up and an aerodynamics package carried over almost in its entirety from the Ford Racing Boss 302.
http://media.ford.com/article_displa...ticle_id=33064
Old Aug 13, 2010 | 03:02 PM
96_Camaro_B4C's Avatar
The hardware sounds pretty cool. I'm confused by the side pipes, since the car still has mufflers at the back. I guess that was just to get some of that sidepipe sound (sort of like the sound tube going into the interior) without going overboard on heat and exhaust being that close to the window / doorsill?
Any word on price? I'm guessing it is NOT going to be around the price of a base GT, as a few rumors had suggested. I would suspect upper $30s if not $40k...
Old Aug 13, 2010 | 03:36 PM
No talk on the price. However, I would suspect that you are probably right. Probably starting in the high $30's.
Frankly, I think this car is massively exciting. It is all about the handling. Geez, I need to win the lottery, as there are so many new cars that I want.
My take on the side dumps, if I understood the article correctly, is that they could be easily modified to be the true exhaust, as they pull from before the mufflers. They couldn't do it from the factory, completely, because of noise regulations.
Old Aug 13, 2010 | 03:42 PM
z28 justin's Avatar
I wish I could afford one of these. They almost make it sound like you can unbolt part of the exhaust and just run with the side pipes alone. Adjustable shocks with easy access are nice too.
Old Aug 13, 2010 | 04:07 PM
Bob Cosby's Avatar
Some engine tidbits...
“In keeping with the spirit of the original, the new Boss 302 engine achieves its maximum power output at speeds at or above 7,500 rpm,” says Harrison. “Unlike the original engine, however, low-speed torque and driveability are uncompromised thanks to twin independent variable camshaft timing (Ti-VCT) technology and computer-aided engineering design tools.”
Harrison and his team began exploring Boss 302 concepts starting with the engine’s ability to breathe – essential to the production of horsepower. Because credible track performance requires high power production between 5,000 rpm and 7,000 rpm, the team needed a new approach to intake manifold design.
Borrowing from the Ford Daytona Prototype engines, the resulting short-runners-in-the-box design virtually eliminates lag when the throttle is snapped open while producing peak power output at high rpm.
“The effect of the new intake design is dramatic,” says Harrison. “When I took the prototype car to Mustang Chief Engineer Dave Pericak, he took a short drive, tossed me the keys and said ‘Book it…it’s in the program.’ He knew what we were onto, and that’s really the point where the Boss 302 was born.”
To take advantage of the racing intake manifold, cylinder head airflow was fully optimized by CNC porting the entire intake and exhaust port and combustion chamber. The painstaking machining process takes 2.5 hours per head to complete.
To accompany the higher peak-power engine speed, the team had to engineer a lightweight, high-speed valvetrain and bulletproof reciprocating assembly that would not only hold together for 150,000-plus miles but also produce power at peak rpm.
“What most people don’t realize is that engine stresses increase exponentially as engine speeds rise,” explains Harrison. “So moving up from GT’s 7,000 rpm redline required significant re-engineering of many different parts. Sacrificing reliability and usability over the GT engine was never an option.”
Some of the Boss-specific parts contributing to the Boss 302 V8’s output and durability include:
- Revised composite intake system with shorter runners, inspired by Daytona Prototype racing engines, for high-rpm breathing
- Forged aluminum pistons and upgraded sinter-forged connecting rods for improved strength, needed for the higher combustion pressures and engine speeds
- New high-strength aluminum-alloy cylinder heads with fully CNC-machined ports and chambers for exceptional high-rpm airflow without sacrificing low-speed torque
- Lightened valvetrain components to provide excellent dynamic performance up to speeds well above the engine redline
- Sodium-filled exhaust valves for improved heat dissipation
- Race-specification crankshaft main and rod bearings for higher load capability and improved high-speed durability
- 5W50 full-synthetic oil with engine oil cooler for improved oil pressure and longer-lasting lubrication during extreme racing conditions
- Revised oil pan baffling for improved oil control under racing conditions and during cornering loads greater than 1.0 g
I didn't even touch on the suspension upgrades. This car is a LOT more than just a different shock/spring/tire/brake package.
Old Aug 13, 2010 | 04:19 PM
You tempted??
Old Aug 13, 2010 | 04:30 PM
Bob Cosby's Avatar
You bet. But what's my cost going to be - especially with the inevitable stupidely high dealer markups?
Old Aug 13, 2010 | 04:32 PM
SSCamaro99_3's Avatar
It's a nice package of upgrades. THe only thing I am not in lov with is some of the color/stripe combinations. I wonder if a stripe delete is allowed?
Old Aug 13, 2010 | 04:41 PM
90 Z28SS's Avatar
Their vinyl ....take them off, cuz underneath is one hell of a performance car .
Old Aug 13, 2010 | 05:36 PM
bossco's Avatar
This seems to be Ford's de rigueur performance car oil - I've checked locally to see if anybody has it but it seems only Ford carries it (understandbly so since not many cars use this weight oil) 7 quarts and filter run me 70 bucks every oil change.
On the plus side, it will probably follow the standard oil change interval for the current cars (IIRC every 10k, the my car calls for it every 3-5k depending on usage).
Old Aug 13, 2010 | 05:47 PM
Z284ever's Avatar
I'm really, really impressed by most aspects of this car - especially the work on the Boss motor and suspension. I wish the Camaro team had benchmarked this car rather than the GT500 for what will become the Z/28.
Old Aug 13, 2010 | 06:23 PM
bossco's Avatar
BTW Ford is claiming <--edit-->under the M3's<--edit--> 1:42.964 around Leguna Seca with the Boss
Old Aug 13, 2010 | 06:26 PM
boomer78's Avatar
Originally Posted by bossco
BTW Ford is claiming -->under the M3's<-- 1:42.964 around Leguna Seca with the Boss
1:42.96 is what the M3 does it in.
Apparently its faster.
Edit: you edited before i hit refresh
Old Aug 13, 2010 | 06:43 PM
bossco's Avatar
Although its an eternity in racing, thats about 3.xx seconds (maybe less) off the Z06's time there. Not to shabby given its company.
Old Aug 13, 2010 | 07:09 PM
DAKMOR's Avatar
http://www.youtube.com/watch?v=oDF1US7DkjY
damn right she is.
but really, have you seen the other boss threads? lots of good discussin and whatnot in there too.
