Autocross and Road Racing Technique There is more to life than a straight line
Where to get a Bump Steer kit?
Old Aug 6, 2002 | 10:50 PM
tryme96Z's Avatar
Post Where to get a Bump Steer kit?
..the only place I know is RK Sport. Does anyone else sell them?
96' Z28,Artic White, 6spd,T-tops, leather.
Mods: Yeah I got a couple
My Z
Old Aug 7, 2002 | 12:15 AM
AZ94FORMULA's Avatar
Talking
Baer "Baer Brakes" is the company that make the bump steer kit. RK Sports just sells it. You could buy it directly from Baer.
Thunder Racing might sell them.
LT4 HOT cam, GM heavy duty timing chain, Crane chromemoly pushrods, Comp Cams "R" lifters, K&N FIPK, BBK 58mm TB, ported intake manifold, ported & polished heads w/ 2.00/1.56 valves, 30# SVO injectors, MSD wires, BeCool radiator, CSI elec. pump, March PP kit, Crane 1.6:1 RR's, Crane ignition, AS&M 1-3/4" headers, SLP cat-back, high flow cat, Hurst shifter, Centerforce DF clutch, SLP flywheel, 3" alum. drive shaft, Strange 12 bolt with 3.73's, HAL shocks, Eibach/SLP springs, Granatelli STB & upper panhard rod, ST sway bars, SLP subframe connectors, Steve Spohn racing torque arm, RLCA's & lower panhard rod, Wolfe Race Craft roll cage, 13" Baer brakes, SLP 17" SS wheels, Auto Meter gauges, LT1-Editor and more... Dyno tested: 370 RWHP w/ 358 Torque http://www.geocities.com/crash607/kurt1.html
Old Aug 8, 2002 | 03:29 AM
mitchntx's Avatar
Post
I know of a fella that owns a BAER bump steer kit that might be interested in selling it. It's never been installed.
I'll send him a link to this thread.
[This message has been edited by mitchntx (edited August 08, 2002).]
Old Aug 8, 2002 | 07:10 PM
tryme96Z's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by mitchntx:
</font>
That would be great, THANKS!!!
WTB: LS1 Steering/brake knuckle. NEED ASAP!!! steve@stevenetworks.com
My Z
Old Aug 13, 2002 | 11:20 AM
I CORNER's Avatar
Post
The only manufacturer that I know of that makes this kit is BAER. Unfortunately, it did not properly fit my setup (& may have problems with your set-up). RK Sport gave me a full refund.
My car uses Global West Tubular Upper Control Arms and LG Motorsports boxed lower control arms. I have the car lowered 1 inch and set to 1.5 deg negative camber static. With the BAER bump steer kit installed, my toe alignment was undrive-ably toe-out. Dimensions of threading and spherical rod joint provided, had no adjustment room left. My friendly mechanic wasted 2 hours trying to make it work, when I arrived to pick-up the car. Fortunately, I kept the original tie-rod ends in the trunk and they worked fine.
Victor Lamb
Aug 26, 2017 02:52 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
