Wheel spacers
Old Feb 20, 2003 | 04:28 PM
horseplay's Avatar
Wheel spacers
Ok guys...I may get linched for asking this.....I recently bought ZO6 18s and I dont care for the offset. The offset is 56mm and I was hopin it would be alright. I originally wanted 50 mm offset but I couldnt pass up this deal. Would 1/4 inch wheel spacers adversely affect anything? I hate to use spacers but Im gettin kinda desperate as I look at these wheels.........Its honestly not that bad but not what I wanted.
If I shouldnt use 1/4" spacers what is the most I could go without hurting anything.......Any info is appreciated
thanks.......Nate
Old Feb 20, 2003 | 05:17 PM
BMC95TA's Avatar
I would like to know too......
Old Feb 20, 2003 | 10:17 PM
Z28BICOL's Avatar
I'm not an expert on this subject by any means, but by using spacers, you're altering the geometric parameters of your wheels. It could damage your bearings prematurely for one.
Old Feb 20, 2003 | 11:10 PM
horseplay's Avatar
I understand that point but it wouldnt be any different than using the correct offset....Im not going extreme ...just to an offset like ZR1 wheels. The thing Im worried about most is the wheel studs...will they be long enough for the spacers and wheels?
1/4 inch spacers at the most
Old Feb 20, 2003 | 11:15 PM
pu12en12g's Avatar
You would need longer studs, and it wouldn't be recommended.
Old Feb 20, 2003 | 11:42 PM
Z28BICOL's Avatar
But if you must have the wheel studs, ask Summit about their ARP 100-7708 studs.
force10
Aug 10, 2015 08:30 AM
Slayer
Jul 4, 2015 03:06 PM
BLK1997Z28
May 2, 2015 01:26 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
derty
Aug 31, 2002 12:28 AM
