Trans Am Sleepy Eyes
Old Mar 4, 2008 | 12:50 AM
  #76
drivefast4fun's Avatar
ok, this is a crappy picture, but here is what I have. I can always snap another for ya if you dont get the gist of it.
To plainly answer your question, yes, I just put in a new stop. I retained the wire on the bottom as well, for stability (hopefully). The rusty looking bolt is already in that panel, I just manually screwed the light to the height I wanted it to open, marked it, then drilled the stop and the panel together (I just clamped it so it would stay), then put in that stainless one. if I ever want to change the height, I can just put in a wider or narrower piece of iron/aluminum.
Old Mar 4, 2008 | 01:00 AM
  #77
88irocz28's Avatar
So the motor senses the restriction from the new stop and stops running automatically? Wouldn't want the motor applying force against the gear and stripping the teeth out. I always thought the headlight module decided how long to run the motor for lowering and raising the headlight?
I kinda get what you're saying but the pic doesn't make much sense right now because I have no idea of perspective. I presume this picture of of the drivers side headlight in the up position taken from engine bay where the radiator would have been?? Could you also post a couple of picture of how this looks with the headlights open?
Old Mar 4, 2008 | 03:37 AM
  #78
the pic is from the front of the car, nose off, front bracket off too. I will take some nice pictures for you tomorrow with our better camera and pm them to you.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
force10
Aug 10, 2015 08:30 AM
Fastbird93
Jul 11, 2015 04:37 PM
Campbellb48
Jul 5, 2015 06:31 PM
