Fernco TB / intake adapters...but in color...
Old 04-08-2003, 05:56 PM
pu12en12g's Avatar
Does anyone know where to get that Fernco TB / Intake adapter but in various colors ?
I believe it is the 3 x 3.5 adapter that I will need...
pu12en12g is offline
Old 04-08-2003, 06:23 PM
Super Moderator
Brent94Z's Avatar
Not sure what exactly you are looking for but did you check here?
http://www.fernco.com/home.html
Brent94Z is offline
Old 04-08-2003, 09:42 PM
If you are trying to connect the MAF sensor direct to the TB, as on a WS6, you need the 3x3" Fernco connector. Sewer pipes are black... Fernco connectors are black.... what do you want for $6, including the 2 S/S clamps
Fernco 3x3 on a 58mm Holley
You can get "silicone" hoses in various sizes and colors... perhaps your local speed shop, particularly one that caters to imports (do not mean anything negative here......), might have them available. They just cut the length you need from a long piece. Blue ones are used a lot for S/C installs.
Injuneer is offline
Old 04-08-2003, 09:51 PM
Shamrock98TA's Avatar
I have an LS1, so I'm not sure on what size hose would be needed for an LT1. I used a fernco coupler for awhile but the thing was such pain to get back on everytime I had to take the lid off and it was just barely stuck on there anyway, that I finally just trashed it. Here's what I went with http://www.shop.airflowonline.com/Me...tegory_Code=HH
It looks a lot nicer (it looks better in person than in the pic) than the fernco did and fits 10 times better.
Another alternative, if you want a colored hose, is to get one from here: http://www.bakerprecision.com/silicone.htm
Shamrock98TA is offline
Old 04-08-2003, 10:11 PM
AW/whiteZ-28's Avatar
Try local Import shops they should be able to get them in the size you need I see red yellow and blue ones all the time in those places.
You doing that split intake I showed you?
AW/whiteZ-28 is offline
Old 04-09-2003, 10:43 AM
pu12en12g's Avatar
White:
Yup and I'm going speed density
MAF =
Shamrock:
Thanks man ! ! Those are some good prices. I will be going with a silicone reducer then ! ! Should be pretty sweet ! ! I'll post pics once I am done with the custom intake.
NewsBot
05-19-2015 09:30 AM
T/A lt1
10-10-2002 03:14 PM
T/A lt1
09-05-2002 06:53 PM
T/A lt1
08-16-2002 11:24 AM
T/A lt1
08-15-2002 01:53 PM
Quick Reply: Fernco TB / intake adapters...but in color...
