Fernco TB / intake adapters...but in color...
Does anyone know where to get that Fernco TB / Intake adapter but in various colors ?
I believe it is the 3 x 3.5 adapter that I will need... |
If you are trying to connect the MAF sensor direct to the TB, as on a WS6, you need the 3x3" Fernco connector. Sewer pipes are black... Fernco connectors are black.... what do you want for $6, including the 2 S/S clamps :) :) :)
Fernco 3x3 on a 58mm Holley You can get "silicone" hoses in various sizes and colors... perhaps your local speed shop, particularly one that caters to imports (do not mean anything negative here......), might have them available. They just cut the length you need from a long piece. Blue ones are used a lot for S/C installs. |
I have an LS1, so I'm not sure on what size hose would be needed for an LT1. I used a fernco coupler for awhile but the thing was such pain to get back on everytime I had to take the lid off and it was just barely stuck on there anyway, that I finally just trashed it. Here's what I went with http://www.shop.airflowonline.com/Me...tegory_Code=HH
It looks a lot nicer (it looks better in person than in the pic) than the fernco did and fits 10 times better. Another alternative, if you want a colored hose, is to get one from here: http://www.bakerprecision.com/silicone.htm |
Try local Import shops they should be able to get them in the size you need I see red yellow and blue ones all the time in those places.
You doing that split intake I showed you? :D |
White:
Yup :) and I'm going speed density MAF = :bs: Shamrock: Thanks man ! ! Those are some good prices. I will be going with a silicone reducer then ! ! Should be pretty sweet ! ! I'll post pics once I am done with the custom intake. |
