You want intresting Intake
Old Feb 17, 2004 | 07:54 PM
Hot Rod Hawk's Avatar
Well I'll spill my guts
You've notice the Holley Stealth Ram?
Have you noticed its lower section is a weind tunnel ram base with injectors...
Have you notice it uses the same base to plenum gaskets as a weind dual 4bbl upper plenum...
Dual progressive 1000 cfm throttle bodys and a tunnel ram, a cast piece... not $$$$ sheetmetal.
sure makes one think if you had aftermarket ecm
Thoughts??
Old Feb 17, 2004 | 10:07 PM
got_hp?'s Avatar
intresting........i had to read that 3 times before i got the mental picture!
Old Feb 17, 2004 | 10:19 PM
SStrokerAce's Avatar
I've been looking at that thing, just that it's STUPID tall!
Bret
Old Feb 21, 2004 | 08:19 PM
sseeya's Avatar
Originally posted by SStrokerAce
I'd convert one if someone wants to try it out. I'd like to see what's up with one, so if anyone want's to pony up I'll do the conversion. $290 from Summit.
Bret
Bret, you posted this in a previous thread about intake manifolds back in June. Did you ever find anybody who was interested?
Old Feb 21, 2004 | 08:42 PM
FASTFATBOY's Avatar
Buddy of mine here in town already has one on his LT1, looks mean, runs well. Break out the die grinder and wafer wheel.
He is using it as it came from Holley
David
Old Feb 22, 2004 | 12:06 PM
Bud M's Avatar
Re: You want intresting Intake
Originally posted by Hot Rod Hawk
Dual progressive 1000 cfm throttle bodys and a tunnel ram...
Thoughts??
Old Feb 23, 2004 | 02:14 PM
T/A lt1's Avatar
I looked at it already and thought the same thing. HRH how much did you p/u by going from a LT1/4 intake to that intake you have now? I have considered going this route myself and already have an intake, Victor E ported, all I would need would be injector bungs, rails and a throttle body. LMK Later Clint
Old Feb 23, 2004 | 06:15 PM
kmook's Avatar
Advanced Tech Moderator
http://web.camaross.com/forums/showt...hreadid=194309
Old Feb 24, 2004 | 03:21 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Bret
I said I would try it back then. Joe Overton is doing a custom solid cam for me right now and Accel Gen 7 DFI. I think it's time to get rid of the LT4 intake. I'm willing to do this. I would like to dyno first to see were I'm at now, and then switch over. Now, How close to bolting right up, is this thing. If it makes any difference, I'm running AFR 210's.
Old Feb 24, 2004 | 03:29 PM
PNYKILR's Avatar
I was also looking into this.
intake
Go to Multi-Port Fuel Injection. Then go to New EFI. This has been mentioned on here before.
Neal
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
Countryboychevy
Jun 13, 2015 02:49 PM
maybe2fast
Mar 26, 2015 08:34 AM
