Question about building motor
Old Feb 23, 2004 | 05:32 PM
wicked_95z's Avatar
On the last main cap is there supposed to be a freeze plug in the last available hole on the block?
Old Feb 24, 2004 | 11:40 AM
wicked_95z's Avatar
One of the chevy magazines I have says dont forget to put a plug in that hole but my machinist says that there is a pressed ball in that hole. Do I need to worry about this or is that pressed ball what is supposed to be in there and no plug
Old Feb 24, 2004 | 11:45 AM
MaxRaceSoftware's Avatar
there is supposed to be a welch plug there
i've never seen a pressed "ball" used there before ???
i just pop the plug out before cleaning block and tap that hole very carefully to correct depth and install pipe plug
you have to light check this depth visually
you can go too far down and block or partially block off the other passage
or go back and use welch plug like it was from factory
either way..a plug of some sort has to be there
Old Feb 24, 2004 | 02:42 PM
wicked_95z's Avatar
So the welch plug stops flush with the block and is not supposed to block the passage that runs perpendicular from the main journal to the oil filter by-pass about 1/2 an inch down that hole.
Old Feb 24, 2004 | 02:59 PM
there is a small lip/register machined in that hole that locates the proper OEM depth for the welch plug
you have to use a very good quality NPT tap
because when it hits this register , the tap has 2 make approx 2 more threads to be able to put a pipe plug
if the pipe plug route is the way you want to go
i "Light" check all passages
and Varsol flow test all passages
caught a brand-new Dart Big M block not completely drilled thru in the number 3 main by flowtesting all oil passages
Old Feb 24, 2004 | 11:01 PM
i always purchase the Pioneer Brass-freeze plug kit for the SBC 400 block..even for 350 cid
that way you get a couple of extra Brass freeze plugs
overtime , it amounts to quite a lot
Old Feb 25, 2004 | 05:43 AM
racer7088's Avatar
Thumbs up
The LTx cars have a ball bearing that is made for that hole but it's still the same place and everything as the plugs on old SBCs.
Moshbmx1
Jan 20, 2015 03:27 PM
ChrisFrez
Jan 18, 2015 08:05 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
squirrels
Jul 13, 2002 01:58 AM
