Is it possible to have a motor that won't ping regardless of the amount of advance?
Old Mar 23, 2004 | 09:31 PM
davepl's Avatar
I have a 396LT4 with 9.0:1 compression, good quench, and 92 octane fuel.
It will not ping no matter how much timing I dial in.
Could it be that this motor won't detonate on too much advance alone?
Old Mar 23, 2004 | 10:56 PM
Stephen 87 IROC's Avatar
How do you know it's not pinging? An engine will only ping under load. A computer controlled engine will detect ping (knock) and automatically retard the timing. If everything is working properly, you'll probably never hear a ping and will only notice a slight lack of power.
Now if you're using a scan tool to watch for any pinging that's a differnet story.
My engine burns alcohol. Even with 13:1 compression I can have my timing far advanced and it won't ping.
Old Mar 23, 2004 | 11:00 PM
davepl's Avatar
Yes, I was logging and saw no detected ping or retard. Even at 35, 40, 50, and 60 degrees total advance.
It was obviously losing power the more I went, but I wanted to see how far before it would knock, and it never did, and I thought that was weird!
Old Mar 23, 2004 | 11:16 PM
12Second3rdgen's Avatar
If you think about how an internal combustion engine works, you will eventually reach a point where the spark really isnt doing anything. I am surprised your motor even ran with that much timing.
Old Mar 24, 2004 | 10:51 AM
Pro Stock John's Avatar
Keep messing with it and you will fu%% up the motor. Hope you have not made any runs with all that timing.
Old Mar 24, 2004 | 11:07 AM
davepl's Avatar
Really? How? Exactly how will too much timing with no detonation harm the motor, oh wise one?
Old Mar 24, 2004 | 11:21 AM
Even if it does not audibly ping it's running too hot and you are going to burn stuff inside. I saw it happen on a Procharged LT1 WS6. You eventually burn head gaskets.
Old Mar 24, 2004 | 11:58 AM
I know you arent talking to me but to add to this, you are eventually going to reach a point where you you are sparking before the intake valve has even closed, so any cylinder pressure made is going to be blown back up the intake. That is why a lot of times when someone tries to start a car with too much advance, if their starter will even turn the motor over, that you get those narly flames coming out of the carb/tb.
Old Mar 24, 2004 | 08:56 PM
I'm kinda wondering if the advance you think you're setting the engine to is actually advancing? Maybe it's not changing at all hence no pinging.
Old Mar 25, 2004 | 09:58 AM
Good point Steve.
Old Mar 25, 2004 | 10:43 AM
4drLT4's Avatar
Yeah...can't imagine advancing the timing that severely, without the consequences of your actions showing up on a logger. Either way, it's not a grand idea to push the envelope that way, as mentioned above.
Old Mar 25, 2004 | 03:28 PM
Are you doing all this with the stock LT1 PCM? How are you changing timing? What are you using for data logging?
Old Mar 25, 2004 | 10:18 PM
EddieP's Avatar
I had a buddy in college that drove a 3rd gen with DFI, and swore up that the 50* of total timing he ran produced the most power and was safe... I didn't see how he was getting away with so much timing, but he insisted it would be fine (couldn't hear any knock). Anyway, I was helping him do an oil change a few weeks later and came across something rather interesting... the magnetic drain plug was covered with large chunks of piston rings! He's now a mechanical engineer for ford doing engine calibration of all things.... guess he knows better now!
Old Mar 31, 2004 | 02:48 PM
Botch's Avatar
And I wondered why my F-150 pings on 87 octane.........?
parkers Z28
Mar 11, 2016 08:14 PM
Noenav
Dec 6, 2014 07:35 PM
nophix
Nov 30, 2014 10:26 PM
squirrels
Jul 13, 2002 01:58 AM
