Opinions on engine build..
Old Mar 22, 2007 | 08:56 PM
hotrod18_69's Avatar
Ok heres what i have going.. I haven't bought pistons yet.. And getting the heads flowed next month.. Now here is what i have come up with for Compression ratio and DCR soo far.. I am pretty sure my heads are 53cc's.. Also having them check as well.
Right now with Mahle pistons -5cc my SCR is 11.93 and DCR is 8.84
What do ya think.. With a good tune could it run on 91? Or am i crazy.. It won't be an everyday driver, but it will get driven alot on the street and to and from the track every other weekend..
Heres a run down:
Mahle pistons -5cc ( haven't bought yet )
5.7 rods
3.480 stroke
4.125 head gasket bore
.039 head gasket thickness
0 deck ( haven't decked it yet )
4.030 bore
CC 306
290/307 adv. dur.
112 LSA
IC 108
Seat timing Open Closed
Intake 37 BTDC 73 ABDC
Exhaust 89.5 BBDC 37.5 ATDC
Old Mar 22, 2007 | 10:04 PM
chuck's Avatar
Why the 4.125" head gasket for the 4.030" bore?
The DCR is really pushing it for 91 IMO. You might consider a thicker head gasket although it won't help quench.
Old Mar 23, 2007 | 08:02 AM
rskrause's Avatar
Moderator
it's hard to say, so before I venture a WAG, why 91 octane? Is that the best you can get in your area?
Rich
Old Mar 23, 2007 | 08:47 AM
Rich
Rich,
Yeah. I wish i was still back in Illinois.. We had 93 back there..
91 is the best i can find out here in AZ..
Old Mar 23, 2007 | 10:51 AM
I've had a pair of Fel-pro 1074's laying around and was just going to use those..
I don't really want to run a thicker gasket either. I want my quench under .040
Best i can hope for is when i get my heads CC'd, that they come back bigger than what i think they are.. 54 or 55 would make me happy..
Old Mar 23, 2007 | 02:14 PM
rskrause's Avatar
Moderator
I think it will work but will be marginal. You mention you are in AZ - one important variable is altiude. Higher is better, at least as far as octane requirement is concerned. Other things include temperature, tune, and rpm range. The worst conditions would be a hot motor, high air temps, and WOT at low rpm with lots of advance. Stay away from thiose conditions if you want to avoid detonation. Also, run a plug a bit colder than stock.
Rich
Old Mar 23, 2007 | 05:32 PM
Altiude here is 3300 feet.. It does get pretty hot here during the summer. Hot air temps. Thanks for all the pointers Rich, and i plan on running TR6's..
I'll know more once i figure out what my head CC's are..
Thanks guys!
Old Mar 23, 2007 | 07:46 PM
89TramsAmGTA's Avatar
I agree that you are pushing things for 91 octane. I see you have not bought your pistons yet. Maybe buy some with more cc? I'm running 8.5:1 DCR with my L98 on 91 octane and .035 quench.
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
97z28k&N
Jan 9, 2015 04:58 AM
1996LT1Z28
Dec 1, 2014 01:01 AM
Omega9
Aug 2, 2002 12:33 AM
