Opinions on engine build..
Ok heres what i have going.. I haven't bought pistons yet.. And getting the heads flowed next month.. Now here is what i have come up with for Compression ratio and DCR soo far.. I am pretty sure my heads are 53cc's.. Also having them check as well.
Right now with Mahle pistons -5cc my SCR is 11.93 and DCR is 8.84
What do ya think.. With a good tune could it run on 91? Or am i crazy.. It won't be an everyday driver, but it will get driven alot on the street and to and from the track every other weekend..
Heres a run down:
Mahle pistons -5cc ( haven't bought yet )
5.7 rods
3.480 stroke
4.125 head gasket bore
.039 head gasket thickness
0 deck ( haven't decked it yet )
4.030 bore
CC 306
290/307 adv. dur.
112 LSA
IC 108
Seat timing Open Closed
Intake 37 BTDC 73 ABDC
Exhaust 89.5 BBDC 37.5 ATDC
Heres a run down:
5.7 rods
3.480 stroke
4.030 bore
CC 306
290/307 adv. dur.
112 LSA
IC 108
Yeah. I wish i was still back in Illinois.. We had 93 back there..
91 is the best i can find out here in AZ..
I don't really want to run a thicker gasket either. I want my quench under .040
Best i can hope for is when i get my heads CC'd, that they come back bigger than what i think they are.. 54 or 55 would make me happy..
I think it will work but will be marginal. You mention you are in AZ - one important variable is altiude. Higher is better, at least as far as octane requirement is concerned. Other things include temperature, tune, and rpm range. The worst conditions would be a hot motor, high air temps, and WOT at low rpm with lots of advance. Stay away from thiose conditions if you want to avoid detonation. Also, run a plug a bit colder than stock.
Rich
Rich
Altiude here is 3300 feet.. It does get pretty hot here during the summer. Hot air temps. Thanks for all the pointers Rich, and i plan on running TR6's..
I'll know more once i figure out what my head CC's are..
Thanks guys!
Thanks guys!
