LT1 Hot Cam Advice, let's do and "advanced" look at this
Old May 15, 2003 | 09:37 AM
  #91
Chris 96 WS6's Avatar
Sorry guys, that should be 117.5 LSA.
The point of emphasis should be 120 intake centerline.
Old Mar 9, 2012 | 12:39 PM
  #92
Bersaglieri's Avatar
Re: LT1 Hot Cam Advice, let's do and "advanced" look at this
Originally Posted by formula11e
The adv. duration is 279/287 from the GM performance parts catalog.
Originally Posted by AdioSS
Do you know if they use .004 or .006 or what for their advertised numbers?
I"m planning on using a cam with 3* less on the intake and 3* more on the exhaust
From what I've found the advertised duration for the Hotcam @ .006 is 272/281. They aren't horribly lazy when compared to the advertised duration on the closest Comp XE lobes 3313/3315 [218/230 @ .050] which rated @ .006 lift are 270/282.
I'm running the Hotcam with 1.65 rockers which nets .544/.544 lift and it ran pretty good.
-Dustin-
Old Mar 9, 2012 | 12:45 PM
  #93
greenformula94's Avatar
you just brought back a 9 year old post.
Old Mar 9, 2012 | 02:55 PM
  #94
I do that from time to time, but at least the right info is here to help folks make a more informed decision.
-Dustin-
Old Mar 9, 2012 | 04:17 PM
  #95
Michael Michaud's Avatar
Smile Re: LT1 Hot Cam Advice, let's do and "advanced" look at this
well this thread sure helped me . I just bought my 95 Z/28 last august and need all the help I can get . ha ha ha !
Old Mar 19, 2012 | 02:01 PM
  #96
JIMS1999CONVZ28's Avatar
WOW, I got an email on this since I was watching this tread years ago. Since then I modifed the 1999 Conv Z28 with a cam hotter than the "Hot Cam" and got 11.8 with stock heads at the track.
Then I got a 1993 Z28 and built a Pro stocker and that cam has a .630 lift, solid w/ rollers (and about $25,000 in motor, compter, and the list goes on and on); that runs a 10.7. There both in the garage since Premium fuel is over $4.00 per gallon and 114 racing fuel is over $11.00 per gallon.
Hard to belive so much has changed in all these years.
Jim
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
Smokn '94 Z
Jul 28, 2002 02:38 AM
