LT1 Hot Cam Advice, let's do and "advanced" look at this
Originally posted by Mindgame
Trey,
I think the problem with people in general is that they don't really know what the hell they want. Either that or their expectations are just too high.
No brain surgery here.... just decide on how much power you want to make (be realistic), decide whether that level of power is going to be something you can live with on a daily basis... decide how much maintenance you're prepared to do to keep everything alive and go with it.
Keep in mind that everything should work together... the cam, converter, rpm range, gearing, everything. For what you're after (according to your other post) 425-450 rwhp... it's simple cause so many people have already "been there done that". Have fun.
-Mindgame
Trey,
-Mindgame
i'm being conservative
After reading this section for a few weeks, I only wish it was so simple. Between fred and phil's posts-
Originally posted by D James
Sweet, thanks for the info, I've been seeing lately all these people with big cams saying it perfect for the street, and since I haven't messed with to many cams, zero blower cams It made me worry a little bit with the large spread in duration and the 114 LSA. I would be interested in hearing a soundclip, I imagine it sounds similar to the cc 305, but not exactly the same.
sent you some sound clips let me know if you can't open them
Jim
Hi, I didn't get any e mail or private messages, so if you could re send another one, I'll see if I'm getting them. I am very curious to how this cams going to sound. -Thanks
As far as the cam, I can now say after reading all these comments, that it should be big enough and produce enough power. At first I thought it might be to small cause of posts like this http://web.camaross.com/forums/showt...t=ex+230%2F242
This is the step up blower cam, which seems a lot wilder, but around the same specs as the cc306, so I don't know how well it would work with a blower, but it is surely big. So what is the optimal psi I should run with this cam. My goal is around 600 fwhp, maybe a little more. I figure if I'm going to throw all that money into an expensive bottom end plus the price of a charger, I might as well go all out, especially if you guys think it needs a bigger blower. I was intending on using 12-14 psi, any more seems like it might be trouble.
Mr. James: what blower are you running, what CR, and what heads? In general though, if the blower flows in the 1000cfm range and you have decent heads and exhaust you will be able to make in the 600rwhp range (with a manual tranny) and should see boost in the 12-14psi range. This would be true using any of the XE cams that have been mentioned (214/224, 224/236, 230/242, etc.). Though as I said before, unless you absolutely can't get over the internet myth that "bigger is always better", you should go with a smaller rather than a bigger cam. Peak hp gains of 20-30rwhp at the top, if it's at the expense of drivability and low end torque, is a poor tradeoff for a street car. If you truly don't care about drivability and low end, have springs that will handle the lift and good heads, etc., there are some bigger cams you could consider. It's all in what you want and what parts combo you are running.
Choosing the correct lobe center is important, as is determining how much advance to have ground into the cam. The blower will need to "tuned" to match the cam by correct choice of pulley sizes to maximize the benefit of the cam.
Good luck.
Rich Krause
Good luck.
Rich Krause
Originally posted by Jason Short
Not to "front" on anyone opinion here...
but...I think this discussion is kinda apples to oranges. Look at what the HOT cam is designed for. Max tq and hp on stock heads? no. Could there be a better cam for torque and power? yes. Does the HOT cam suck? no. Is the HOT cam too big for stock heads? no. Is it a great cam (aka key word here is package) for a stock headed motor? YES.
I dont really see anyone getting a better deal than a HOT cam kit for $475 which includes cam, springs, locks, and 1.6rr's. That is a great deal for someone wanting to keep it at that level of performance.
Personally I have driven some well tuned HOT cam cars that make very good tq and hp. Low 12s at 112-113 in a stock headed motor is pretty good.....killer if you look at the price of the kit.
If you went and purchased a cam, rockers, springs, etc...all seperatly in a package that would make more power you are looking at $800.
Cant beat the HOT cam kit for a nice little NA upgrade on a budget.
JMO tho
Jason
JMO tho
Jason
I got all the "advance look" you need.
Check out the video of the hotcam and stock headed LT1 hanging with a bone stock 2001 Z06. It's in the kill section. The Z06 is barely pulling away. Awesome.
Jeff D.
Check out the video of the hotcam and stock headed LT1 hanging with a bone stock 2001 Z06. It's in the kill section. The Z06 is barely pulling away. Awesome. Jeff D.
While we are doing cams the "advanced way" Id like to discuss big cams on stock bottom ends for a bit. I have QUICKLY earned a reputation on this forum as the "cam scrooge." People are litteraly email/IM/Pm/Flaming me inpost about how i'm trying to "**** on everyones parade" because I'm sorry about my cam selection (which I am to an extent, but that has nothing to do with this)
However, I must be thick headed because I cant understand the point of a radical (236/242) cams on stock bottom ends. Some of these cams will rev beyond what the stock bottom wants to rev safely and what the average set of LT1 castings flow. Granted some can make them flow very well- like phil, but the average person doesn't port like phil.
If the relativly puney LT4 HC revs 62-6400- I can only imagine the 236/242 cam. And some wanting to go up to the 242/248
. I cant see revving that high in a hydro roller without a rev kit, good lifters, and stiff springs.
Then some bring up the point of shifting early because only 15-25 peak hp will be lost.
first off, why not get a cam that will allow you to stay in your powerband?
second- aside from the 20hp (which doesn't come easy at all), you lose the gearing advantage. now your fighting the next gear for the 300 rpm instead of holding the previous shorter gear for that amount of time. Plus now, your lower in your powerband and have to fight your way back up into your power range.
Maybe this is all just miniscule and neglegable? The only answers I ever get are "wait till I get my __(insert expensive rebuild here)__" or "its still fast" second only to the all might "it pulls hard through the whole band" responces that in conjuction with 4 quarters will get you a dollar anywhere
After seeing so many "bigger is better" cam responces, I'm seriously wondering what I'm missing.
Thanks in advance- (hehe no pun intended- thanks in advance, andvanced tech
Trey
. I cant see revving that high in a hydro roller without a rev kit, good lifters, and stiff springs. Then some bring up the point of shifting early because only 15-25 peak hp will be lost.
.After seeing so many "bigger is better" cam responces, I'm seriously wondering what I'm missing.
)Trey
This whole post is about that, why use a bigger cam on a stock bottom end? You hit the nail on the head with that one.
The "bigger is better" theory on cams is the problem, nobody will ever feel the change in their butt from a ZZ3 vs a LT4, but they will on the track. Too many internet "leg humpers" make broad choices for everyone based on their butt dyno. (leg humpers is my term for the lemming metality where everyone has to do what everyone else is doing. It's also a funny mental image, like a one armed money trying to hump a football. Man that still makes me laugh)
Most big cams are going to make your car feel like a monster at 6000rpm, but all that time you could be getting up there quicker with the ZZ3 cam and the 20 ft lbs more of TQ it makes down low.
The whole reason for camshaft selection is to maximize the power in the useable RPM band. Average power wins races, not peak.
Bret
Originally posted by rskrause
...Though as I said before, unless you absolutely can't get over the internet myth that "bigger is always better", you should go with a smaller rather than a bigger cam. Peak hp gains of 20-30rwhp at the top, if it's at the expense of drivability and low end torque, is a poor tradeoff for a street car. If you truly don't care about drivability and low end, have springs that will handle the lift and good heads, etc., there are some bigger cams you could consider. It's all in what you want and what parts combo you are running...
Good luck.
Rich Krause
Good luck.
Rich Krause
He would have done better putting part of that money into suspension and tires...
It's not what is perceived to be faster,...it's who makes it to the finish line first.....
I too would be interested in the replies to Trey's post above. I would like to hear what some of the more "experienced" members of the board have to say. I know treys post is mainly regarding my car, but I have allready talked to him about it and the board isnt a place for it anymore. So keep the replies coming.
Brian
Brian
OK,
I'm building a forged 383. I have lingenfelter ported LT4 heads. I have a 2800 vigilante.
Before my 2800 stall I had 4.10's and I thought the car ran great.
now with 3.23's and the 2800 vigilante it runs good but I think I need more gear.
I think with my stall I need my power band in the 3-3500 range
I'm currently running the hot cam in my stock headed car.
I thought I wanted something in the 306 range for more power and thump.
My machine shop said the hot cam would probably be better because the 306 makes most of it's power up top.
What do you guys think works best for these heads?
I'm having the machine shop flow and cc them and then match a cam to them.
I want 400rwhp na and then spray a 100shot on top of that for 500rwhp
Do the LT4 intakes have a worse problem sealing than the regular intakes? I noticed someone mentioned that in this thread.
Is there anything that can be done to fix this?
