Hey need some opinions
Old Feb 4, 2008 | 06:58 PM
ta96Joe's Avatar
I dont know if this belongs here but I didnt get any response in the ls1 section. I have a 96 TransAm and I want a 8 sec car my mods are in the sig. Im looking for opinions on the motor I have been searching and I came up with a 408 forged bottom end 12.5-13.0 comp ET 240+ heads a solid roller w/shaft system full fuel system and a victor jr with a carb or elbow to stay fuel injected plus a 250-300 shot of nitrous. thanks for any info Joe
Old Feb 4, 2008 | 07:57 PM
rskrause's Avatar
Moderator
What is the question?
Rich
Old Feb 4, 2008 | 08:21 PM
jerminator96's Avatar
Rich
I think he's asking if that's enough. I'm not sure how much power it takes to get into the 8's but just get yourself a good nitrous setup and if 300 isn't enough spray 500.
Things that will help figure this out:
How much power are you/will you be making?
Race weight?
What size rubber?
Old Feb 4, 2008 | 08:55 PM
ta96Joe's Avatar
Yeah Im asking if that will be enough. Im wanting 600-700 rwhp on motor then add the nitrous. The race weight Im not sure of I weigh 230 and the car is stripped no ac no heat all susp is chromemoly if it could be had that way I have the bmr k member a arms and 24 adj qai shocks manual rack manual strange drag brakes and bogarts electric water pump so Im running the short manual adj belt for the alternator carbon fiber 3.5 ds
Old Feb 4, 2008 | 09:48 PM
Boosted_Z28's Avatar
This question gets asked here from time to time and usually, most people don't like the answer(s) they get. It's a TALL,TALL order to build an LT-x based motor that normally aspirated, will make 600-700fwhp, let alone rwhp. Not saying that it can't be done, but you are going to need a real fat wallet to make that happen. Sorry, just noticed you are looking to do this with an LS-x. It would be a little more feasible, but you are going to need the best of everything. An 8 second car that can be driven on the street will require more maintenance than most people are willing to do and all that HP will in most instances will be unusable, not to mention the long list of necessary suspension/chassis mods that will need to take place to support that kind of power. Moreover, the tuning, expecially with n2o, will need to be spot on. An 8 second track car will require a minimum of a 10 point rollcage, window net, 5-point harness, parachute, chassis certification, nomex drivers suit with gloves, shoes, helmet and neck brace, competition driver's license, etc. etc. As you can see the list of required expensive, exotic engine parts, required supporting modifications to the car in order to support that kind of HP and the necessary safety items add up in a hurry.
Let's say you can get your car's weight down to 3200 lbs. (No small task with a 4th gen F-body) and using a very crude ET/HP calculator, you will need to be making roughly 850 hp to run 9.00 @ 150 mph. An 8.00 pass will require somewhere over 1200 hp. Just my .02. I'm sure some others will chime in as well.
Old Feb 4, 2008 | 09:57 PM
mdacton's Avatar
If you have to ask what it would take then just forget it.
I want alot of thing too.....If you just want to go fast...then buy a race car allready built. Look at all the guys that have been impressive over the years...where are they now? In debt......MIA.....
Old Feb 4, 2008 | 10:44 PM
Slow down a little man, use more punctuation and it would be easier to understand what your saying.
I don't see you getting 600rwhp with those heads, and you still haven't said what cam your using.
If boosted thinks you need 1200hp, you better go ahead and plan on a 600 shot. That should get you there. I hope your chassis is up to it.
Old Feb 4, 2008 | 10:47 PM
mdacton's Avatar
mightymouse made like 1100 h.p. I think it ran a 9.70 But he does drive it on the street alot I see it around quite a bit
Old Feb 5, 2008 | 12:27 AM
Kraest's Avatar
Retired
I replied to about 3 PMs from this guy along with answering his question in the LS1 Tech section. You can shut this one down if you want, Fred.
ecthemc
Jun 19, 2015 06:54 AM
95_Z28/SS
May 20, 2015 01:23 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
87Aerocoupe
Jan 10, 2015 07:27 PM
smacz28
Aug 6, 2002 01:51 PM
