Going from carb to fuel injected questions
Old May 27, 2003 | 09:17 PM
BLK97Z28's Avatar
Not sure where to post this, but my gf's dad is looking at a 1967 mustang. He wanted to know how much it would cost to convert it from a 4-barrel carb to fuel injected? The guy said it's a 302 bored to a 351 (not positive on that, this is second hand info).
Not sure why, gas mileage most likely.
thanks for any replies.
Old May 27, 2003 | 09:33 PM
rskrause's Avatar
Moderator
It really depends on exactly what he wants. But a system like the Holley Commander, which is designed to be retrofutted, is in the $2,200 range for a complete kit.
Rich Krause
Old May 28, 2003 | 02:36 AM
WS6 TA's Avatar
Ford 351 Windsor engines are tall deck versions of the smaller small blocks (302, 289…), so they require a different intake manifold….
If you want to use factory parts, there are a few options, but the most popular are using the SFI intake used on the full size trucks and some full size cars _look_ like the 5.0 intakes, but they’re actually larger 351 intakes. There is also a factory CFI setup that works well, but is better suited for low rpm applications.
There’s plenty of aftermarket support for FI 351W’s since they were used in the early lightnings and are a fairly common mustang swap.
If it’s a 351 Cleveland or M… well then you’ve got a whole different problem. With the C, you’ll get stuck building something yourself (I don’t know of any ready made intakes out there) but it’s not that hard to drill one of spider style (single plane) intakes for injectors and adapt them to a TB. If it’s an M, most of the C parts will work (similar layout) but because of various other issues it’s not worth modifying.
Old May 28, 2003 | 09:07 AM
BLK97Z28's Avatar
So, at the cheapest you guys think it would be around $2,000? does that include labor?
I need to find out what engine it is exactly for yall. come back later
Old May 28, 2003 | 10:25 AM
OldSStroker's Avatar
Re: Going from carb to fuel injected questions
Don't convert for fuel mileage; the payback is terrible!
IF you could raise the average fuel economy from 15 to 20 mpg, it would take about 70,000 miles to payback the $2200.
I like Rich's conversion also, but figure a couple of Cs to get it installed.
How about just changing the carburetor to something like Edelbrock's Thunder Series easily adjustable carb, or even a reconditioned Performer carb. A good carb guy could select the proper carb, linkage, etc, and set it up.
My $.02
Old May 28, 2003 | 10:46 AM
Mindgame's Avatar
And yet there is another option for you.... Venturi Fuel Injection or VFI. Check with Barry Grant: http://www.bgfuel.com/bgfuel/63.aspx
-Mindgame
Old May 30, 2003 | 10:02 PM
BLK97Z28's Avatar
You guys are great. Thanks for the help. he doesn't want to fool with the Holley carb that's on there now and once he heard how much switching to a FI system was, he decided not to get that car. Now he's looking at Supras maybe if he gets one I'll get to drive it!
thanks again!
InfernalVortex
Jan 17, 2015 09:35 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
Brady
Jul 29, 2002 10:30 PM
