Fuel experts inside, tell me if this is normal.
Old Apr 30, 2003 | 03:50 PM
BrianZ28's Avatar
I have a 396 stroker, with a large camshaft. I also have a intank Holley fuel pump. Anyways the fuel pressure is set @ 38psi. When I slightly give throttle, the fuel pressure will go down to 32psi. At wot the fuel pressure goes back up to 38psi and holds there. Is this normal, or is my fuel pump laying down. Thanks for any info.
Old May 1, 2003 | 10:08 AM
The fuel pressure is set at 38psi with or without vacuum compensation? What kind of fuel pressure regulator? What does the balance of the system look like? Since you didn't post in LT1 Tech, 3rd Gen Tech, or some other appropriate forum, can we assume you have something more complex?
Old May 5, 2003 | 03:31 PM
BrianZ28's Avatar
I have a Accell adjustable fuel regulator.
Old May 5, 2003 | 03:42 PM
kmook's Avatar
Advanced Tech Moderator
Brian, what about Freds other questions? All the info needs to presented for people to help.
Old May 5, 2003 | 03:49 PM
BrianZ28's Avatar
Sorry about that, 38psi with the vacuum hose connected. I have a Holley intank fuel pump, I think it is the 255 pump through a Acell regulator, I also have 30lb injectors.
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
carl.froehlich
Mar 13, 2015 12:38 AM
squarehead
Nov 21, 2014 08:02 PM
