First gen SBC heads on an LT1???
Old 11-11-2004, 07:44 AM
Sleeper_Z's Avatar
I just got an amazing deal on a set of HVH 23 degree race heads and I was wandering if it would be at all possible to convert them to the revuse flow coolent system to work on my LT1. The heads are 69cc 2.08/1.65s, fully ported and flow around 330s on the intake and mid 200s on the exhaust. I would really like to use these heads and the intake bolt differance is no big deal sence I will probibly have to go with a sheet metal intake cause the stock LT1 intake doesnt have enough material to it to port match to these heads. If anyone has any info please post. Thanks very much!
Jeremy
Sleeper_Z is offline
Old 11-11-2004, 09:43 AM
crash4cyl's Avatar
Re: First gen SBC heads on an LT1???
Going to from SBC to LT1 may be harder than the LT1 to SBC. I know thirdgen.org has a lot of guys using LT1 heads on SBC motors, but I haven't heard of the opposite. couldn't hurt to check it out.
Chris
crash4cyl is offline
Old 11-11-2004, 10:06 AM
You might actually have better luck with this on LT1 Engine Tech.... there are people there running Gen 1 heads on the LT1.
Injuneer is offline
Old 11-11-2004, 02:14 PM
n2oblkz
Guest
Posts: n/a
Sleeper Z, email sent about this topic.
Old 11-11-2004, 03:33 PM
n2oblkz
Guest
Posts: n/a
Here are a couple of links that can help you out.
Ben
http://web.camaross.com/forums/showt...ead+conversion
http://web.camaross.com/forums/showt...5&pagenumber=1
Old 11-11-2004, 05:55 PM
Eff
Eff's Avatar
I've heard of people doing it. Guess it wouldn't be a bad idea. Since they would retain heat better than aluminum heads.
hey can you send me info on it too? mreff555@hotmail.com
Eff is offline
Old 11-11-2004, 06:51 PM
Sleeper_Z's Avatar
Eff,
The heads I am wanting to use are aluminum. They are HVH race heads. The links that were posted didnt really give me any good info that I was hopeing for. If anyone can help me out Id appriciate it. Thanks
Jeremy
Old 11-11-2004, 07:03 PM
ltlhomer's Avatar
Originally Posted by Sleeper_Z
Eff,
Jeremy
You can get the conversion done for around $250 so it's not bad at all. PM me if you want to know who I would recommend.
Take care,
Sean
ltlhomer is offline
Old 11-11-2004, 09:04 PM
nateh's Avatar
I ran some converted Brodix -10 heads on my car until they broke this year. Conversion is not that bad if the shop knows what to do. Weld up coolant passages on the intake side. Add oil drainback holes, open new passages on the engine side, and open holes in the back side for the crossover tube. Machine the intake and deck sides flat.
nateh is offline
Old 11-11-2004, 09:10 PM
OneFlyn95z28's Avatar
we were not even going to fill the holes on the intake side with my Brodix 18- heads Instead of drilling the heads for the air bleed I was using back water passages
Not that hard if a good shop does it
OneFlyn95z28 is offline
Old 11-11-2004, 10:05 PM
Dave69Z's Avatar
Till what broke? The heads? Related to the conversion?
Dave
Dave69Z is offline
Old 11-12-2004, 10:47 AM
nateh's Avatar
It's a long story. After a lot of trouble, I had everything working correctly and my car was running quite well. One of the valve seats broke, sending a piece into the combustion chamber. It dinged a piston and the head a little. The heads are easily repairable, but I need a new valve and I'd definitely want new seats. I decided to go back to the stock castings and I freshened the stock bottom end with new rings and bearings (and a new piston).
I had visions of fixing the heads and putting them on a new shortblock with a Victor EFI manifold. They would make some serious power. After the money I've spent though, I'm not going to use them. I even had a stainless y-pipe made to go with the headers. If anyone wants the whole kit (heads, springs, ARP studs, modified headers (ASM/RKSport midlength),braided stainless crossover tube, etc., I'll let them go for an insanely good price, just to get them out of the way.
nateh is offline
10-31-2016 11:09 AM
parkers Z28
03-11-2016 08:14 PM
oldschool
02-09-2016 09:21 PM
Steve69SS396
Track Kill Stories
15
08-10-2015 02:45 PM
HectorM52
Parts Wanted
01-10-2015 09:01 PM
Quick Reply: First gen SBC heads on an LT1???
