Engine choice for fast bracket/Quick 8/16 car
in the field, then it's all about reaction times and consistency.
Well, this is new to me also.....I thought it was heads up pro tree.
I guess that changes things somewhat......as long as you make the field.
I don't agree! A LS7 head is so far beyond ANY 26°-18° BBC head that pound for pound a LS motor, especially with LS7 heads will walk all over a BBC. In terms of cost, you can build decent LS motors for the same price as decent BBC's and have a lighter package that can make more HP per the same cube or more HP per cube, take your pick.
Bret
Rich, cost effiectively a Iron LS can handle some serious grunt with a 6.0L iron block. They are not light like 230lbs or something crazy, but they are around $350 or so compared to the $1800 LSX block. (even then total engine weight would be 490lbs)
I was planing to one day run a centrifigal blower 365 cube iron block motor in my 64 GTO, but I'm thinking it might make a better cruiser, or CP AutoX car! My plan was put billet caps on the 6.0L iron block sitting here with a aftermarket head like a Dart. That's easy for 408 cubes if need be and should handle 7500rpm without a fuss.
I still like the 383 LT1 idea ;-) lol
Bret
Bret
Bret,
I agree the LS engine in an engineering marvel compared to the antique BBC.
The combustion chamber layout alone is enough to justify the decision. The
pluses are many, great main cap configuration, good port design, availability
of good cheap blocks, a light compact package, a wide selection of heads and
compatibility with common transmissions to mention a few.
Rich,
Can you explain the 0.3 breakout, does this give advantage to the faster car?
Rich,
I have a 6.0L block that has been sitting in the shop for a couple years now, just don't want to put it in something because the weight is insane - I prefer to go fast in the twisties, rather than just a straight line.
Rich
From mortec:
12573581...364...98-04...crossbolted cast iron, Gen.III, 6.0L, truck
12577184...364...98-04...crossbolted cast iron, Gen.III, 6.0L, truck
12551364...364...98-04...crossbolted cast iron Gen. III, 6.0L, truck
I don't have a scale that goes high enough to weigh one, It's a shock when you try an move one though - it doesn't look as heavy as it is. I pick up and move gen I's solo, no way am I trying that with one of those.
It's funny how the wind is blowing in the direction of a 6.0 LSx truck block engine.
When a very similar topic came up two years ago:
http://web.camaross.com/forums/showt...II+differences
Lo and behold, the very last post in that thread:
http://web.camaross.com/forums/showp...8&postcount=62
