DCR on pump gas
Old Dec 1, 2005 | 11:09 PM
95Zedder's Avatar
DCR on pump gas
I am starting to build a 396 with a forged bottom end, flat top -5cc pistons, AFR 220cc Compitition heads, and a solid 260/260 .660/.660 cam and a HEI style pro-billet distributor. I was wondering what kind of compression should I set my DCR to allow me to use 93 octane pump gas safely and still run 36 degrees of ignition advance?
Old Dec 2, 2005 | 12:01 AM
marshall93z's Avatar
Re: DCR on pump gas
A search will yield great results. It's been beat to death here.
With that being said 9.0 is about the max you wanna go and that is with good cooling, tight quench, and a good tune.
Old Dec 2, 2005 | 12:23 PM
jimlab's Avatar
Re: DCR on pump gas
BTW, If you've already purchased the parts listed, your DCR is already "set". Cylinder head combustion chamber volume, piston dish volume, and valve timing all affect the dynamic compression ratio.
Old Dec 6, 2005 | 01:04 AM
1racerdude's Avatar
Re: DCR on pump gas
If ya have a .035 quinch ya may not need 36* of timing.With that cam ya are needing a 12-12.5 static to get to a 9.0 DCR(guess not knowing the cam spects)
ad356
Apr 16, 2015 05:38 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
simple
Aug 11, 2002 11:56 AM
dmaastr
9
Jul 1, 2002 02:22 PM
