cyl head torque values plz.
Old Jun 11, 2005 | 01:55 PM
dynomight's Avatar
i have searched, but i havent been able to get comfortable with a definitive answer for my app. if i could get a solid answer from someone, i would appreciate it.
i am using arp perf. series bolts on worked LT4 heads. i am running a vortech sc as well. i have the heads torqued to 22 ft/lbs right now, and am unsure of how is best to proceed with my motor. would it be sufficient to angle them the additional 67/80 degrees, or would it be better to step them to 50 ft/lbs, and finish at 65 ft/lbs?
thanks for your help.
jb
Old Jun 11, 2005 | 02:40 PM
sssalah's Avatar
Re: cyl head torque values plz.
The ARPs are not torque to yield so the angle method wouldn't apply, just tight them as you said to 50 then to 65 using appropriate lubricant and sealer were necesury. Make sure to tight them down in the correct sequence.
Old Jun 11, 2005 | 03:56 PM
dynomight's Avatar
thanks...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
smokin5s
Jul 24, 2003 10:47 PM
