cementing bottom 1/2 of block???
Old Oct 19, 2003 | 04:02 PM
  #31
phaint's Avatar
Originally posted by TAYLORMADE
Make sure you remachine the main bores it will pull and push it out of shape. Also will need to rehone if it's already done, but then it will be to loose on shirt clearance. Has it had any machine work done to the block yet? Read my other post above if you don't let the filler harden long enuff before you machine it it will pull or push the block enuff to mess up the machine work. I.E. unround cylinder bores and main housing!!!!!!!
You said before you didn't want to weld because you'd have to remachine block. You still have to remachine after filling block!!
[This message has been edited by TAYLORMADE (edited July 11, 2002).]
He should machine it again for free considering he ruined the block. Its his fault it should be his problem.
Victor Lamb
Aug 26, 2017 02:52 PM
Fastbird93
Jul 11, 2015 04:37 PM
camaro02DK
Jul 5, 2015 09:04 AM
TitoPR221
May 26, 2015 12:20 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
