Can you have too big of an air filter?
Old Sep 19, 2007 | 12:54 AM
AdioSS's Avatar
West South Central Moderator
I know that too small can hurt, but can too big be bad?
And how do you know what size filter is too small without measuring kPA?
I'm putting together a cold air intake, and I want to make sure I get a filter that won't hurt performance any time soon.
Old Sep 19, 2007 | 10:02 AM
Z28SORR's Avatar
No such thing as to big. As for to small you either rely on the manufacture in stock or near stock configs. Or for anything unusual, most filters have max CFM for the filter on the box or in the advertizing, so all you need is your engines max CFM.
Old Sep 27, 2007 | 09:58 PM
95custom's Avatar
with a stock computer it can hurt if you have to much intake, it will almost act as if there is a caccum leak, and the check engine light may come on because of extreme lean conditions.
Old Sep 28, 2007 | 12:04 PM
You don't really believe that, do you? Its totally incorrect.
Old Sep 28, 2007 | 12:20 PM
AdioSS's Avatar
I have run stock vehicles at the track with no air filter with no problems.
I guess I asked the wrong question.
I'm wanting to know how you figure out what the minumum size air filter you should run.
Old Sep 29, 2007 | 10:24 PM
95custom's Avatar
ive done it, it needs some restriction or the car will not continue running. Try running the motor with an open intake and see how far it gets you... now would you like to chime in on some contructive comments?
Old Sep 29, 2007 | 11:21 PM
AdioSS's Avatar
let me guess, you tried running an LT1 without the MAF?
My best ET was with no air filter, 85mm MAF, rubber boot to throttle body.
Old Sep 30, 2007 | 12:26 AM
95custom's Avatar
Im sorry, im wrong. The more I think about it the more I see how misunderstood I was.
Old Sep 30, 2007 | 07:58 AM
96capricemgr's Avatar
If the MAF is plugged in but not connected to the TB then the car will not run. If the MAF is unplugged it will run, be slightly harder to start but still run pretty well actually.
Cheston if you look back through the SS forum archives some kid "etnies" or something like that had a massive diesel filter on his car, might be a source of inspiration. Think the exact one he had was a tad overkill, not that that hurt, but still might be worth a look.
Want to say the think was 16" long at least and 6-8" round paper.
I have thought about making a box for the RAISS to allow a LARGE flat paper element rather than the cones. I have one cone now that is restrictive and the other has too deep of a cone in the end that gets too close to the MAF and readings get inconsistent because I tried to descreen it to measure the running difference and ruined the screen.
Old Sep 30, 2007 | 11:44 AM
On my 381ci LT1 (set up to run speed-density, so MAF is not an issue) removing the air filter has no negative effect whatsoever - in fact, it increases engine power. I've run it on an engine dyno with and without the induction system, and it makes more power without all the plumbing and the filter. A velocity stack on the throttle body, with the correct radius on the outer edge will improve HP, but that's because it smoothes air flow and reduces the vena contracta compared to the blunt, irregular shape of the throttle body housing.
Your intake does not need "some restriction" any more than your exhaust needs "backpressure". Some fundamental reading on building performance engines might be a good idea. Look at the David Vizard books.... he deals with basic issues and supports his positions with real-world test data. Here's a good one:
http://www.amazon.com/exec/obidos/AS...0target=_blank
Old Oct 2, 2007 | 11:03 AM
Z28SORR's Avatar
Of course I can't find it now, but there are formulas for calulating the max CFM based on engine size, head and intake flow rates, etc. I'm sure "Desk Top Dyno" and the like, have this in them.
Once you have this rate, most go with a slightly larger filter. For instance, say your engine pulls a max of 728cfm at 6000rpm. You would be good with a filter/air duct good for 750cfm. or larger.
Old Oct 2, 2007 | 12:15 PM
AdioSS's Avatar
If DesktopDyno or DynoSim have that calculator, then I haven't found it.
Old Oct 2, 2007 | 05:57 PM
350ci times (rpm divided by twobecause it is a 4 stroke) = then divide by 1728 the number of cubic inches in a cubic foot
This assumes 100% VE for ease of math, multiply the results by whatever VE you deem fit.
For 6000rpms that means 607cfm the thing you have to consider is what depression was the filter rated at???? If rated at a high depression a "750cfm" filter will be a restriction.
If a filter is rated at say 1" of mercury which would be a good number for manifold vacuum at WOT and it flows 750cfm then it should be of no meaningful restriction.
PCLZ28
Dec 24, 2015 05:19 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
kksi
Mar 21, 2015 09:03 PM
Jazsun
Dec 29, 2014 12:14 PM
